esackbauer
Thank you for taking the time to check, but where do you see that my IP has a bad reputation?
When I scroll down to the bottom of the test, it says: “Your server is not blocklisted. It compares your server’s IP address with 24 of the most common IPv4 blacklists.” And on mxtoolbox.com, I also don’t see my IP being blacklisted.
