- Edited
Hi There,
Lastly I am working on a laravel project and installed the mailcow. But I have auth issue. Do you have any idea about this auth issue how I can solve it? SOGo works well as expected. [USES CLOUDFLARE]
Btw is that logical to use as SMTP Username and password as defined in the section “Sender-dependent transports”?
My .env configuration
MAIL_DRIVER=smtp
MAIL_HOST=mail.secreturl.com
MAIL_PORT=25
MAIL_USERNAME=DefinedusernameinSDT
MAIL_PASSWORD=DefinedpasswordinSDT
MAIL_ENCRYPTION=tls
thank you for solution suggestion
SMTP 587
SMTP 465
[unknown]
BTW server Architecture is aarch64
