DocFraggle
I tried running docker compose down then docker compose up -d but nothing.
Also the header_checks line that was added in the /home/mailcow-dockerized/data/conf/postfix/main.cf disappeared
    Olgaa
    I guess you want this for Incoming messages!
    in your case create the file:
    /home/mailcow-dockerized/data/conf/postfix/list_unsub_header
    add to:
    /home/mailcow-dockerized/data/conf/postfix/extra.cf
    header_checks = regexp:/opt/postfix/conf/list_unsub_header
    run:
    docker compose restart postfix-mailcow
    although i have no clue how this will work in a multidomain setup just for one domain.
      piperino
      I tried the steps and nothing yet! đŸ€” does it take some time to work ?
        Olgaa
        actually no. Header was there immediately there on incoming messages.
        You have checked the message source. right?
        Yes, the List-Unsubscribe header is missing :/
        By the way this is the contents of /home/mailcow-dockerized/data/conf/postfix/list_unsub_header
        /^Content-Transfer-Encoding:/i PREPEND List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
        which I got from Mailtrap Icon here
        , is it correct?
        i used exactly the same manual
        the only difference is the path in the extra.cf
        what is the output from:
        docker-compose exec postfix-mailcow postconf -n | grep -i header
        run below and post the output if something found
        docker-compose logs postfix-mailcow | grep prepend
          I did a little bit more of fiddling around. So please read the below carefully.
          The example I’ve explained earlier just works with incoming mails. As I already wrote.
          E.g. from gmail to mailcow!
          1. In postfix you have to differentiate SMTP”D” and SMTP. The “D” is responsible for incoming mails. So, what you
            need is “smtp_header_checks =” in extra.cf for outgoing a assume.
          2. BUT “smtp_header_checks” is already configured per default and is using “anonymize_headers.pcre”
          3. You can either completely override “anonymize_headers.pcre” by setting smtp_header_checks =
            regexp:/opt/postfix/conf/list_unsub_header in “extra.cf”, what I’ve done for testing, or try to add the content of
            your “list_unsub_header” at the bottom of “anonymize_headers.pcre” (should work)
          4. There are two issues with the above. “anonymize_headers.pcre” might be overwritten with an update, or you might
            having obsolete content in “list_unsub_header” if the content changes in
          5. And the last point is, create your regex so that it’ll will match. Check in recipient’s mailbox for an existing header field. As example, if you send a mail from SoGo with no attachment there there is no “Content-Transfer-Encoding” in the header.
          Final Word:
          You might want to look around for another solution to run newsletter or a mailinglist rather than using mailcow, since it is some sort of closed solution.
          Even though I haven’t found one use case yet which is not covered by mailcow for running a regular, very well designed “mail appliance”.
          Over and out.
          maybe @DocFraggle or @esackbauer you can give a few words since you seem to have a lot of experience with mailcow
          piperino
          docker-compose exec postfix-mailcow postconf -n | grep -i header gives me:
          smtp_header_checks = pcre:/opt/postfix/conf/anonymize_headers.pcre
          smtpd_sasl_authenticated_header = yes
          smtpd_tls_received_header = yes
          and
          docker-compose logs postfix-mailcow | grep prepend gives:
          postfix-mailcow-1  | Feb 27 21:58:44 442c313eb6bb postfix/cleanup[483]: 75E6B13C1B04: prepend: header Content-Type: text/html; charset=utf-8 from mail-qt1-f181.google.com[209.85.160.181]; from=<anupam.convodigital@gmail.com> to=<contact@mydomain.com> proto=ESMTP helo=<mail-qt1-f181.google.com>: List-Unsubscribe: mailto:unsubscribe@mydomain.com?subject=unsubscribe
          postfix-mailcow-1  | Feb 27 22:16:21 442c313eb6bb postfix/cleanup[483]: 834C613C0A61: prepend: header Content-Transfer-Encoding: quoted-printable from mail-pf1-f171.google.com[209.85.210.171]; from=<madison@teamrisems.com> to=<updates@mydomain.com> proto=ESMTP helo=<mail-pf1-f171.google.com>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 27 22:26:51 442c313eb6bb postfix/cleanup[602]: D1A8513C1A2C: prepend: header Content-Transfer-Encoding: quoted-printable from mail-yb1-f174.google.com[209.85.219.174]; from=<team@dobleskemarketing.com> to=<news@mydomain.com> proto=ESMTP helo=<mail-yb1-f174.google.com>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 27 22:27:45 442c313eb6bb postfix/cleanup[602]: 1366613C1A4F: prepend: header Content-Transfer-Encoding: 7bit from mail176.acems1.com[192.92.97.176]; from=<bounce-3156164-132-221260-contact=mydomain.com@mail172.acems1.com> to=<contact@mydomain.com> proto=ESMTP helo=<mail176.acems1.com>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 27 22:27:45 442c313eb6bb postfix/cleanup[602]: 1366613C1A4F: prepend: header Content-Transfer-Encoding: quoted-printable from mail176.acems1.com[192.92.97.176]; from=<bounce-3156164-132-221260-contact=mydomain.com@mail172.acems1.com> to=<contact@mydomain.com> proto=ESMTP helo=<mail176.acems1.com>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 27 22:44:04 442c313eb6bb postfix/cleanup[794]: 695B713C18EF: prepend: header Content-Transfer-Encoding: quoted-printable from mout.kundenserver.de[217.72.192.74]; from=<nayef@hellosugarsmile.de> to=<contact@mydomain.com> proto=ESMTP helo=<mout.kundenserver.de>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 27 23:48:34 442c313eb6bb postfix/cleanup[1501]: 9848313C0079: prepend: header Content-Transfer-Encoding: quoted-printable from mail-io1-f54.google.com[209.85.166.54]; from=<ashfaque@theideaforges.com> to=<updates@mydomain.com> proto=ESMTP helo=<mail-io1-f54.google.com>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 27 23:58:54 442c313eb6bb postfix/cleanup[1659]: D903F13C18D6: prepend: header Content-Transfer-Encoding: quoted-printable from mout.perfora.net[74.208.4.197]; from=<peytonriley@infinitumsolar.info> to=<contact@mydomain.com> proto=ESMTP helo=<mout.perfora.net>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 28 00:02:40 442c313eb6bb postfix/cleanup[1729]: 7C56A13C1ABD: prepend: header Content-Transfer-Encoding: quoted-printable from mail-qk1-f172.google.com[209.85.222.172]; from=<anupam.convodigital@gmail.com> to=<contact@mydomain.com> proto=ESMTP helo=<mail-qk1-f172.google.com>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 28 00:17:44 442c313eb6bb postfix/cleanup[1862]: C340313C17F6: prepend: header Content-Transfer-Encoding: quoted-printable from mout.kundenserver.de[212.227.126.133]; from=<simon@marketingfilmsmedia.info> to=<updates@mydomain.com> proto=ESMTP helo=<mout.kundenserver.de>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          postfix-mailcow-1  | Feb 28 08:41:47 442c313eb6bb postfix/cleanup[6307]: 3EE2A13C1BC1: prepend: header Content-Transfer-Encoding: quoted-printable from mta-07-3.privateemail.com[198.54.118.214]; from=<samuel@bestpldomains.com> to=<updates@mydomain.com> proto=ESMTP helo=<MTA-07-3.privateemail.com>: List-Unsubscribe: mailto:<unsubscribe@mydomain.com>?subject=unsubscribe>"
          [unknown] Aha! I thought it was for outgoing emails, like when you send an email from mailcow and it shows to the recipient an “unsubscribe” button 😅
          [unknown]
          Adding line /^Content-Type:/i PREPEND List-Unsubscribe: <mailto:unsubscribe@mydomain.com> straight to anonymize_headers.pcre then running docker compose up -d and docker compose restart postfix-mailcow fixes it! đŸ«Ł
          Now there is an List-Unsubscribe header in the source! As you said it might be overwritten after an update but at least it works for now until there is a better solution! Thank you!!! 🙏
            I would also strongly suggest to outsource these kind of things into a separate solution which also allows better management. Especially in EU with GDPR it is easier to document in case of audits or complaints. In bigger companies this is typically done within CRM, but there is also a free open source solution:
            listmonk.app Icon listmonk - Free and open source self-hosted newsletter, mailing list manager, and transactional mails
            Havent tried it yet, but looks decent.
            a month later
            Olgaa
            Any idea how to do that globally? I mean in my case there are a lot of domains which needed the same solution.
            15 days later
            Hi fellow bovine enthusiasts. Given the timing, it may be safe to assume you are/were researching this “List-Unsubscribe” configuration to satiate new deliverability requirements from the “big 3”. Just wanted to add a few things:
            1. Gmail expects a “one-click” unsub; not the mailto: option you’re looking into. This is to facilitate straightforward/automated list removal for their users.
            2. Make sure you understand that, by adding a “List-Unsubscribe” header (regardless of configuration) you’re essentially signaling your intention to send bulk email. This may have unintended consequences–particularly if your “List-Unsubscribe” is misconfigured, inoperable, or otherwise fails to meet Goog’s expectations.
            3. Further to the above, what Goog does with the (possible fact) that you include “List-Unsubscribe” headers, yet _do not send bulk email (5,000/day by their definition
              support.google.com
              Email sender guidelines - Google Workspace Admin Help
              The guidelines in this article can help you successfully send and deliver email to personal Gmail accounts. Starting in 2024, email senders must meet the requirements described here to send email to G
              support.google.com
              ) is an exercise left to speculation and/or trial & error involving significant downside.
            As for us, we plan to hold off on adding these headers to Postfix for now, as our server is strictly used for transactional email.
            Cheers!
