esackbauer Actually even IMAP doesn’t seem to work any more in the gmail app. I tried to configure it using a NAT-Setup and gmail App failed to set up a connection to the Mailcow. Using a VPN and connecting to the internal IP of the Mailcow worked except for the certificate not beeing validated.
The Bluemail app is not having any problems with my setup either using EAS nor IMAP.
If SoGo goes with MAPI over HTTP that would be a good replacement for EAS in my eys.
[unknown] Ich habe HAproxy verwendet um IMAP und SMTP von meinem Cloud-VPS per VPN auf die MailCow zu kriegen, die im Internen Netz läuft.
