I had disabled IPv6 as per the document but still I am unable to receive the mail.
10/29/2025, 11:15:34 PM info 81515100221: to=piyushdesai204@gmail.com, relay=alt4.gmail-smtp-in.l.google.com[142.250.96.26]:25, delay=15496, delays=15494/0.29/1.5/0, dsn=4.7.4, status=deferred (TLS is required, but was not offered by host alt4.gmail-smtp-in.l.google.com[142.250.96.26])
10/29/2025, 11:30:00 PM info 80F90100252: to=piyushdesai204@gmail.com, relay=alt4.gmail-smtp-in.l.google.com[142.250.96.26]:25, delay=1.8, delays=0.45/0/1.4/0, dsn=4.7.4, status=deferred (TLS is required, but was not offered by host alt4.gmail-smtp-in.l.google.com[142.250.96.26])
10/29/2025, 11:29:58 PM info 80F90100252: replace: header Received: from 6a3b47eba317 (mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network [172.22.1.248])??(Authenticated sender: piyush.a@getcollarup.com)??by mail.getcollarup.com (Postcow) wit from mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network[172.22.1.248]; from=piyush.a@getcollarup.com to=piyushdesai204@gmail.com proto=ESMTP helo=<6a3b47eba317>: Received: from [127.0.0.1] (localhost [127.0.0.1]) by localhost (Mailerdaemon) with ESMTPA id 80F90100252??for piyushdesai204@gmail.com; Wed, 29 Oct 2025 23:29:58 +0530 (IST)
the above are the logs and below is confirming that only ipv4 is running in mailcow
root@server1:/opt/mailcow-dockerized# docker exec -it mailcowdockerized-postfix-mailcow-1 postconf inet_protocols
/usr/sbin/postconf: warning: /opt/postfix/conf/main.cf, line 202: overriding earlier entry: smtp_address_preference=any
/usr/sbin/postconf: warning: /opt/postfix/conf/main.cf, line 203: overriding earlier entry: inet_protocols=all
inet_protocols = ipv4
