hisdarkmaterials23
It may be possible with Oracle, i am not sure. The Network setup possibility there are way above my pay grade frankly….
So i just wrote a support ticket.
But there is a difference for sure, if you just setup a PTR Record were you manage your DNS settings for your Domain Name (which for me would be Cloudflare).
PTR needs to be set by your hoster, ISP etc., either via some Settings Option or manually with a ticket.
Maybe someone with more technical insight can explain it better…
EDIT:
From the Oracle Help Sites: https://docs.oracle.com/en-us/iaas/Content/Network/Concepts/reverse_dns.htm
