Hi, I’m running into an issue when trying to use an external Nginx reverse proxy (outside Docker) to access the Mailcow web interface.
When I configure the reverse proxy outside the Docker environment (on the host, pointing to 127.0.0.1:8080), I get repeated Nginx errors like this:
recv() failed (104: Connection reset by peer) while reading response header from upstream
Example Nginx log entries:
2025/06/18 16:02:15 [error] 141448#141448: *82 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 128.116.250.196, server: webmail.arcoiriscreative.es, request: “GET /admin/system HTTP/1.1”, upstream: “http://127.0.0.1:8080/admin/system”
2025/06/18 16:02:42 [error] 141448#141448: *84 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: 128.116.250.196, server: webmail.arcoiriscreative.es, request: “GET /favicon.ico HTTP/1.1”, upstream: “http://127.0.0.1:8080/favicon.ico”
However, when I move the reverse proxy into a container (inside Docker), everything works perfectly. The Mailcow web interface loads as expected with no connection issues.
System setup:
Mailcow running in Docker
External Nginx reverse proxy on host (127.0.0.1:8080)
TLS termination on the external proxy
iptables rules allow connections as needed (DROP default policies, with specific ACCEPTs)
Troubleshooting so far:
Verified that the backend is listening and responds correctly
No container crashes or backend errors in Mailcow logs
Only occurs when using a host-based reverse proxy
Expected behavior:
Mailcow should respond correctly to reverse proxy requests from the host (non-Docker) Nginx, just like it does when proxied from within Docker.
Any advice or known limitations regarding this setup?
Thanks!
Logs:
docker logs –tail=50 mailcowdockerized-nginx-mailcow-1
10.213.101.8 - - [18/Jun/2025:16:30:51 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:30:56 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:31:22 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:31:45 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:31:49 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:31:50 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:32:28 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:32:33 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:32:38 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:32:43 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:33:13 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:33:31 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:33:36 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:33:46 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:34:16 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:34:19 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:34:24 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:34:51 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:34:54 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:35:21 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:35:26 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:35:38 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:35:54 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:36:29 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:36:31 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:36:36 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:37:03 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:37:23 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:37:33 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:37:38 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:38:07 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:38:16 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:38:41 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:38:45 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:38:46 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:39:23 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:39:25 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:39:48 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:39:53 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:40:00 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:40:06 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:40:29 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:40:30 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:40:34 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:40:36 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:41:07 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
10.213.101.8 - - [18/Jun/2025:16:41:21 +0200] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:41:29 +0200] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.11.1”
10.213.101.8 - - [18/Jun/2025:16:41:34 +0200] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.11.1”
10.213.101.12 - - [18/Jun/2025:16:41:48 +0200] “GET / HTTP/1.1” 200 15 “-” “check_http/v (nagios-plugins 2.4.10)”
docker logs –tail=50 mailcowdockerized-php-fpm-mailcow-1
10.213.101.10 - 18/Jun/2025:16:27:16 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:27:54 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:27:59 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:28:02 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:28:38 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:28:43 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:29:00 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:29:44 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:29:49 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:29:49 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:30:46 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:30:51 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:30:56 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:31:45 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:31:49 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:31:50 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:32:33 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:32:38 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:32:43 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:33:13 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:33:31 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:33:36 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:34:16 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:34:19 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:34:24 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:34:54 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:35:21 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:35:26 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:35:38 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:36:29 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:36:31 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:36:36 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:37:23 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:37:33 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:37:38 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:38:07 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:38:41 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:38:45 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:38:46 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:39:23 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:39:48 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:39:53 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:40:00 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:40:29 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:40:34 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:40:36 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:41:21 +0200 “HEAD /settings.php” 304
10.213.101.10 - 18/Jun/2025:16:41:29 +0200 “HEAD /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:41:34 +0200 “GET /forwardinghosts.php” 200
10.213.101.10 - 18/Jun/2025:16:42:10 +0200 “HEAD /settings.php” 304
Logs:
Logs:
Steps to reproduce:
- Deploy a clean ARM64 virtual machine (tested on Ubuntu 22.04 LTS)
- Install Docker and Docker Compose
- Clone Mailcow repository and check out the latest
2025-05
tag
- Run
docker-compose up -d
to start Mailcow normally
- Ensure
nginx-mailcow
exposes port 8080 on 127.0.0.1
(host loopback only)
- On the host (outside Docker), configure an Nginx reverse proxy with the following:
- Listens on port 443
- Uses
proxy_pass http://127.0.0.1:8080
- Proper TLS config (can be self-signed)
- Access
https://<your-mailcow-domain>/admin/system
from a browser
- Observe in the host Nginx logs:
- Confirm via
docker logs
nginx-mailcow
and php-fpm-mailcow
show no request received on /admin/system
- As a workaround, move the same reverse proxy inside Docker and attach it to the
mailcowdockerized_mailcow-network
- Now
/admin/system
works correctly — confirming it’s a network exposure / forwarding issue
Logs of iptables -L -vn:
Chain INPUT (policy DROP)
pkts bytes target prot opt in out source destination
…. ACCEPT all – lo * 0.0.0.0/0 0.0.0.0/0
…. ACCEPT all – IF_EXT * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
…. ACCEPT tcp – IF_EXT * 10.0.0.X 0.0.0.0/0 tcp dpt:22
…. ACCEPT tcp – IF_EXT * PUBLIC_IP_A 0.0.0.0/0 tcp dpt:22
…. ACCEPT tcp – IF_INT * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
…. ACCEPT tcp – IF_INT * 10.0.0.X 0.0.0.0/0 tcp dpt:22
…. ACCEPT tcp – IF_EXT * 0.0.0.0/0 0.0.0.0/0 multiport dports REDIS_PORTS
…. ACCEPT tcp – IF_EXT * 0.0.0.0/0 0.0.0.0/0 multiport dports CUSTOM_APP_PORTS
…. ACCEPT tcp – lo * 0.0.0.0/0 0.0.0.0/0 tcp dpt:3306
…. ACCEPT tcp – IF_EXT * 0.0.0.0/0 0.0.0.0/0 tcp dpt:3306
…. ACCEPT tcp – IF_EXT * 0.0.0.0/0 0.0.0.0/0 multiport dports 80,443
…. ACCEPT tcp – IF_EXT * PUBLIC_IP_A 0.0.0.0/0 tcp dpt:3000
…. ACCEPT tcp – IF_EXT * PUBLIC_IP_B 0.0.0.0/0 tcp dpt:9090
…. ACCEPT tcp – IF_EXT * 0.0.0.0/0 0.0.0.0/0 multiport dports SMTP_PORTS,IMAP_PORTS,SIEVE_PORTS
Chain FORWARD (policy DROP)
…. MAILCOW
…. DOCKER-USER
…. DOCKER-FORWARD
Chain OUTPUT (policy ACCEPT)
…. ACCEPT all – * lo 0.0.0.0/0 0.0.0.0/0
Chain DOCKER
…. ACCEPT tcp – !br-mailcow br-mailcow 0.0.0.0/0 10.213.101.10 tcp dpt:8080
…. ACCEPT tcp – !br-mailcow br-mailcow 0.0.0.0/0 10.213.101.253 tcp dpt:465
…. ACCEPT tcp – !br-mailcow br-mailcow 0.0.0.0/0 10.213.101.250 tcp dpt:4190
…. DROP all – !br-xxxxxx br-xxxxxx 0.0.0.0/0 0.0.0.0/0
…. DROP all – !docker0 docker0 0.0.0.0/0 0.0.0.0/0
Chain MAILCOW
…. DROP tcp – !br-mailcow br-mailcow 0.0.0.0/0 0.0.0.0/0 multiport dports MYSQL,REDIS,SOLR,CUSTOM_PORT
Logs of ip6tables -L -vn:
Chain INPUT (policy ACCEPT 40 packets, 3033 bytes)
40 3033 MAILCOW 0 – * * ::/0 ::/0
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
0 0 MAILCOW 0 – * * ::/0 ::/0
0 0 DOCKER-USER 0 – * * ::/0 ::/0
0 0 DOCKER-FORWARD 0 – * * ::/0 ::/0
Chain OUTPUT (policy ACCEPT 1538 packets, 98865 bytes)
Chain DOCKER (0 references)
Chain DOCKER-BRIDGE (1 references)
Chain DOCKER-CT (1 references)
Chain DOCKER-FORWARD (1 references)
0 0 DOCKER-CT 0 – * * ::/0 ::/0
0 0 DOCKER-ISOLATION-STAGE-1 0 – * * ::/0 ::/0
0 0 DOCKER-BRIDGE 0 – * * ::/0 ::/0
Chain DOCKER-ISOLATION-STAGE-2 (0 references)
0 0 RETURN 0 – * * ::/0 ::/0
Chain MAILCOW (2 references)
Logs of iptables -L -vn -t nat:
Chain PREROUTING (policy ACCEPT)
1350 77593 DOCKER all – * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL
Chain INPUT (policy ACCEPT)
75 4500 DOCKER all – * * 0.0.0.0/0 !127.0.0.0/8 ADDRTYPE match dst-type LOCAL
Chain POSTROUTING (policy ACCEPT)
1841 137K MASQUERADE all – * !br-mailcow 10.213.101.0/24 0.0.0.0/0
0 0 MASQUERADE all – * !docker0 172.17.0.0/16 0.0.0.0/0
0 0 MASQUERADE all – * !br-<other> 172.18.0.0/16 0.0.0.0/0
Chain DOCKER
0 0 RETURN all – br-mailcow * 0.0.0.0/0 0.0.0.0/0
0 0 RETURN all – docker0 * 0.0.0.0/0 0.0.0.0/0
0 0 RETURN all – br-<other> * 0.0.0.0/0 0.0.0.0/0
Port forwarding rules
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 127.0.0.1 tcp dpt:7654 to:10.213.101.249:6379
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 127.0.0.1 tcp dpt:13306 to:10.213.101.5:3306
4 240 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:110 to:10.213.101.250:110
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:143 to:10.213.101.250:143
2 100 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:993 to:10.213.101.250:993
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:995 to:10.213.101.250:995
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:4190 to:10.213.101.250:4190
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 127.0.0.1 tcp dpt:19991 to:10.213.101.250:12345
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:25 to:10.213.101.253:25
3 180 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:465 to:10.213.101.253:465
6 340 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:587 to:10.213.101.253:587
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:8080 to:10.213.101.10:8080
0 0 DNAT tcp – !br-mailcow * 0.0.0.0/0 0.0.0.0/0 tcp dpt:8443 to:10.213.101.10:8443
Logs of ip6tables -L -vn -t nat:
Chain PREROUTING (policy ACCEPT 0 packets, 0 bytes)
0 0 DOCKER 0 – * * ::/0 ::/0 ADDRTYPE match dst-type LOCAL
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
0 0 DOCKER 0 – * * ::/0 !::1 ADDRTYPE match dst-type LOCAL
Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
Chain DOCKER (2 references)
DNS check:
root@arm-arcoiriscreative-1:/mnt/data/mailcow-dockerized# docker exec -it mailcowdockerized-acme-mailcow-1 dig +short stackoverflow.com @10.213.101.254
104.18.32.7
172.64.155.249
