I have two different domains on my Mailcow setup, but I don’t know how to configure separate SSL certificates for each domain. Additionally, I’m experiencing an SSL error in Thunderbird related to my Mailcow setup. Thanks for your help!
The cert is made with CloudFlare
Here a screenshot of the thunderbird error :
    ByakuraRinne The cert is made with CloudFlare
    Well, you should post this at a Cloudflare forum then.
    Sure, I have no idea how you do this with Cloudflare. Mailcow would do this on it’s own, but without Cloudflare
    can tou tell me even if its not with cloudflare ?
    I added my second domain in the mailcow.conf, but after that, ACME doesn’t seem to issue a certificate for my second domain, only for the first one
      • DocFraggle
        Moolevel 243
      Mailcow isn’t able to determine the IPv6 address of your machine and it seems you added only IPv6 DNS records?
      Yes, for autoconfig and autodiscover, I handle them with another web server, so that’s fine. However, I don’t see any logs indicating an attempt to issue a certificate for ‘nazuna.ovh’
      • DocFraggle
        Moolevel 243
      ByakuraRinne I added my second domain in the mailcow.conf
      What exactly did you add? Please paste the ADDITIONAL_SAN variable
      • DocFraggle
        Moolevel 243
      Did you restart your stack after adding this?
      docker compose down
      docker compose up -d
      yes i do but let me retry
      same
      I’m sorry, I messed up
