Is it possible to call a script upon mailbox or alias creation?
I’m asking because I need to whitelist (via a HTML Post) every address on our inbound mail gateway.
cheers, Thorsten
English
Call external script upon mailbox or alias creation
- Edited
ecdlguy whitelist (via a HTML Post) every address on our inbound mail gateway.
What?
That inbound mail gateway cannot to do callback verification?
Mine can, so I do not need such a workaround.
- Edited
esackbauer That inbound mail gateway cannot to do callback verification?
There are several servers in front, including servers of our university computer center.
I can only guess, but either they decided against callback verification or they just don’t know that it’s possible ;-)
However I’m going to ask them. Would make things easier. Also, at the moment it takes an unpredictable amount of time until the address is not rejected after adding it to the whitelist. I guess this is due to a cronjob.
@DocFraggle thanks for the suggestion!
esackbauer
I’ve been thinking about this a bit more, maybe we are not talking about the same thing.
Sender address verification is happening at our inbound mail gateway.
The purpose of the whitelist is to check the eligibility of the recipient, i.e. check if the recipient exists on the final destination mail server with the mailbox.
With regard to the Wikipedia article you mentioned there seems to be something referred to as “call forwards”:
A related technique is “call forwards”, in which a secondary or firewall mail exchanger can verify recipients at the primary mail exchanger for the domain in order to decide whether the address is deliverable.
cheers,
Thorsten
- Edited
- Best Answerset by ecdlguy
Recipient Address verification (also known as “Callout” or Call forward ), which is what you described as “check the eligibility of the recipient” can be cascaded over several MTAs if they support it, should not take longer than fractions of a second, if the MTAs in the chain trust each other. Or you have some internal greylisting
If you have a proper mail gateway, it is also possible to check for eligible mail addresses via Active Directory or LDAP. Then you would not need the callback verification.
@esackbauer Thanks again ️
