Maybe a timezone issue?
mailcow/mailcow-dockerized1063
English
Outlook Calendar only syncs one way
Nope - i checked. Everything is set to Berlin. Mailcow config, Sogo Settings and Linux Server
I think you are right! I upvoted it.
Wohooo! It seems to be solved with the 2410 Update!
- Edited
Hey @sut,
what Office Version exactly do you have? I just updated to the after your post but with my Office Professional Plus 2019 Version 2410 (Build 18129.20116) it ist stilll not working. Also still not working for a friend of mine with Office 365 and the same build.
Edit: Also what version of mailcow are you running? I’ve got version 2024-08a
Sorry - i am dumb…
I tested with the wrong account. I have one account with Caldav Synchronizer and one with eas. Eas still doesnt work.
Sorry for giving false hope.
Microsoft® Outlook® für Microsoft 365 MSO (Version 2410 Build 16.0.18129.20100) 64 Bit
Did you ever try the 32 Bit version? Works flawlessly for me
FYI, I just upgraded to
Microsoft® Outlook® für Microsoft 365 MSO (Version 2410 Build 16.0.18129.20100) 32 Bit
and tested the calendar sync both ways, works like a charm for me. But as I said, it’s the 32Bit version, I think we had this problem once in another thread which also used the 64Bit version
Thanks for the info @DocFraggle! It makes sense that it may only affect the 64bit version since the exception thrown is an arithmetic overflow. Could be a difference here with 64bit and 32bit version.
Undecided9954 It makes sense that it may only affect the 64bit version since the exception thrown is an arithmetic overflow
Yes, that could be possible. So give it a try then with the 32Bit version, waiting for an update
