DocFraggle I have checked the text records. Heres the raw text from a DNS query:
Heres the one that fails:
dkim._domainkey.example.com. 300 IN TXT "v=DKIM1;k=rsa;t=s;s=email;p=[PUBKEY]"
Heres the one that passes:
dkim._domainkey.example.net. 300 IN TXT "v=DKIM1;k=rsa;t=s;s=email;p=[PUBKEY]"
Both of the public keys are identical. I checked with diff.
I put each public key into a file a and b, heres the checksums:
e00d02fde7afbe2b4c4fe7d7ca3759ccba417999ef57d786e188b1549414b150 a
e00d02fde7afbe2b4c4fe7d7ca3759ccba417999ef57d786e188b1549414b150 b
They are identical records.
If both records are identical and both domains use the same private key, then why should this fail?
I have also just determined that it is not a registrar issue by testing another domain on the same registrar pointing to the same email server.
Now I am really starting to pull my hair out. Only the MAIN domain is having this issue (all other domains MX record point to this main domain, main domain in mailcow, I dont know if there is another term for this).
Hopefully this detail is relevant!
Thanks for the help so far
[unknown] Also I dont know why that happened this was supposed to be a separate post lol.
This is what it was meant to say:
