OK, so I think I have done it, I think I correctly setup sso with roundcube, so I am going to share all of my knowledge:
Before going on…
mail.yourdomain.com is your mailcow host (make sure to use HTTPs)
You need Roundcube running in a seperate container
Your docker-compose.yml should look like this:
roundcube:
image: roundcube/roundcubemail:latest
container_name: roundcube
environment:
DBROUNDCUBE: ${DBROUNDCUBE}
IPV4_NETWORK: ${IPV4_NETWORK:-172.22.1}
IPV6_NETWORK: ${IPV6_NETWORK:-fd4d:6169:6c63:6f77::/64}
ROUNDCUBEMAIL_DB_TYPE: mysql
ROUNDCUBEMAIL_DB_HOST: mysql
ROUNDCUBEMAIL_DB_USER: roundcube
ROUNDCUBEMAIL_DB_PASSWORD: ${DBROUNDCUBE}
ROUNDCUBEMAIL_DB_NAME: roundcubemail
ROUNDCUBEMAIL_DEFAULT_HOST: ssl://dovecot:143
ROUNDCUBEMAIL_SMTP_SERVER: ssl://postfix:587
ROUNDCUBEMAIL_PLUGINS: dovecot_client_ip, archive, managesieve, acl, markasjunk, zipdownload
ROUNDCUBEMAIL_COMPOSER_PLUGINS: "foorschtbar/dovecot_client_ip:~2"
labels:
- traefik.enable=true
- traefik.http.routers.roundcube-mail-secure.entrypoints=websecure
- traefik.http.routers.roundcube-mail-secure.rule=Host(`roundcube.yourdomain.com`)
- traefik.http.routers.roundcube-mail-secure.tls=true
- traefik.http.routers.roundcube-mail-secure.tls.certresolver=cloudflare
- traefik.http.routers.roundcube-mail-secure.service=roundcube-svc
- traefik.http.services.roundcube-svc.loadbalancer.server.port=80
- traefik.docker.network=frontend
volumes:
- ./data/rc/html:/var/www/html
- ./data/rc/config:/var/roundcube/config
- ./data/rc/db:/var/roundcube/db
depends_on:
- mysql-mailcow
- dovecot-mailcow
restart: unless-stopped
networks:
mailcow-network:
aliases:
- roundcube
proxy:
Create a oauth2 app
i. navigate to Admin > oauth2 Apps
ii. now create a oauth2 App and set the redirect uri to https://roundcube.yourdomain.com/index.php/login/oauth
iii. take note of the client id and the client secret
Create config.oauth.inc.php (inside of roundcubes config folder)
<?php
// OAuth
// Enable OAuth2 by defining a provider. Use 'generic' here
$config['oauth_provider'] = 'generic';
// Provider name to be displayed on the login button
$config['oauth_provider_name'] = 'SSO';
// Mandatory: OAuth client ID for your Roundcube installation
// Get this from the oauth2 app in the mailcow UI
$config['oauth_client_id'] = 'your_client_id';
// Mandatory: OAuth client secret
$config['oauth_client_secret'] = 'your_client_secret';
// Mandatory: URI for OAuth user authentication (redirect)
$config['oauth_auth_uri'] = 'https://mail.yourdomain.com/oauth/authorize';
// Mandatory: Endpoint for OAuth authentication requests (server-to-server)
$config['oauth_token_uri'] = 'https://mail.yourdomain.com/oauth/token';
// Optional: Endpoint to query user identity if not provided in auth response
$config['oauth_identity_uri'] = 'https://mail.yourdomain.com/oauth/profile';
// Optional: disable SSL certificate check on HTTP requests to OAuth server
// See http://docs.guzzlephp.org/en/stable/request-options.html#verify for possible values
$config['oauth_verify_peer'] = false;
// Mandatory: OAuth scopes to request (space-separated string)
$config['oauth_scope'] = 'profile';
// Optional: additional query parameters to send with login request (hash array)
$config['oauth_auth_parameters'] = [];
// Optional: array of field names used to resolve the username within the identity information
$config['oauth_identity_fields'] = ['email'];
// Boolean: automatically redirect to OAuth login when opening Roundcube without a valid session
$config['oauth_login_redirect'] = false;
Now when going to your Roundcube main page you will see a “SSO” Button
Setup Dovecot to work with oauth
i. add this to your extra.conf file inside of mailcow/data/conf/dovecot:
passdb {
driver = oauth2
mechanisms = xoauth2
args = /etc/dovecot/dovecot-oauth2.conf.ext
userdb {
driver = static
args = uid=vmail gid=vmail home=/var/vmail/%d/%n
ii. create dovecot-oauth2.conf.ext inside of mailcow/data/conf/dovecot:
grant_url = https://mail.yourdomain.com/oauth/token
client_id = your_client_id
client_secret = your_client_secret
introspection_url = https://mail.yourdomain.com/oauth/profile
introspection_mode = auth
use_grant_password = no
username_attribute = email
