DocFraggle Here is the log from a fresh install of 2023-10a regarding unbound:
mailcowdockerized-unbound-mailcow-1 | setup in directory /etc/unbound
mailcowdockerized-unbound-mailcow-1 | Certificate request self-signature ok
mailcowdockerized-unbound-mailcow-1 | subject=CN = unbound-control
mailcowdockerized-unbound-mailcow-1 | removing artifacts
mailcowdockerized-unbound-mailcow-1 | Setup success. Certificates created. Enable in unbound.conf file to use
mailcowdockerized-unbound-mailcow-1 | [1697470871] unbound[1:0] notice: init module 0: validator
mailcowdockerized-unbound-mailcow-1 | [1697470871] unbound[1:0] notice: init module 1: iterator
mailcowdockerized-unbound-mailcow-1 | [1697470871] unbound[1:0] info: start of service (unbound 1.17.1).
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: service stopped (unbound 1.17.1).
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: server stats for thread 0: 247 queries, 0 answers from cache, 247 recursions, 0 prefetch, 0 rejected by ip ratelimiting
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: server stats for thread 0: requestlist max 4 avg 1.03239 exceeded 0 jostled 0
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: average recursion processing time 0.027722 sec
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: histogram of recursion processing times
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: [25%]=0.00570701 median[50%]=0.00731801 [75%]=0.0128205
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: lower(secs) upper(secs) recursions
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: 0.004096 0.008192 157
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: 0.008192 0.016384 50
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: 0.016384 0.032768 2
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: 0.032768 0.065536 34
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: 0.065536 0.131072 2
mailcowdockerized-unbound-mailcow-1 | [1697471678] unbound[1:0] info: 1.000000 2.000000 2
mailcowdockerized-unbound-mailcow-1 | Setting console permissions…
mailcowdockerized-unbound-mailcow-1 | Receiving anchor key…
mailcowdockerized-unbound-mailcow-1 | Receiving root hints…
mailcowdockerized-unbound-mailcow-1 | [1697530628] unbound[1:0] notice: init module 0: validator
mailcowdockerized-unbound-mailcow-1 | [1697530628] unbound[1:0] notice: init module 1: iterator
mailcowdockerized-unbound-mailcow-1 | [1697530628] unbound[1:0] info: start of service (unbound 1.17.1).
As you can see the service is 1.17.1 instead of 1.18
DocFraggle The latest version in 2023-10a should use
unbound-mailcow:
image: mailcow/unbound:1.18
if(window.hljsLoader && !document.currentScript.parentNode.hasAttribute('data-s9e-livepreview-onupdate')) {
window.hljsLoader.highlightBlocks(document.currentScript.parentNode);
So if you’re still running on 1.17.1 there’s something odd
Absolutely correct. I have the same values. And docker ps shows an 1.18 container running but the container itself seems to run service as 1.17.1.
Looks like it is a bug.
