I have the same issue as poqdavid. I think there is a misunterstading cause there a two Test you can run. One is named “Data Query Service Test” and the other “Public Mirrors Test”.
With the manual changes which DocFraggle mentions the “Data Query Service Test” indeed flips to green. But the result of the “Public Mirrors Test” does not change. I think here is another postfix config needed.
I think i found a soultion.
i added this block to my extra.cf:
reject_rbl_client zen.spamhaus.org=127.0.0.[2..11],
reject_rhsbl_sender dbl.spamhaus.org=127.0.1.[2..99],
reject_rhsbl_helo dbl.spamhaus.org=127.0.1.[2..99],
reject_rhsbl_reverse_client dbl.spamhaus.org=127.0.1.[2..99],
warn_if_reject reject_rbl_client zen.spamhaus.org=127.255.255.[1..255],
So my full extra.cf looks like this:
myhostname = myhostname
smtpd_recipient_restrictions = check_recipient_mx_access proxy:mysql:/opt/postfix/conf/sql/mysql_mbr_access_maps.cf,
permit_sasl_authenticated,
permit_mynetworks,
check_recipient_access proxy:mysql:/opt/postfix/conf/sql/mysql_tls_enforce_in_policy.cf,
reject_invalid_helo_hostname,
reject_unauth_destination,
reject_rhsbl_sender XXXXXXXXXXXXXXX.dbl.dq.spamhaus.net=127.0.1.[2..99],
reject_rhsbl_helo XXXXXXXXXXXXXXX.dbl.dq.spamhaus.net=127.0.1.[2..99],
reject_rhsbl_reverse_client XXXXXXXXXXXXXXX.dbl.dq.spamhaus.net=127.0.1.[2..99],
reject_rhsbl_sender XXXXXXXXXXXXXXX.zrd.dq.spamhaus.net=127.0.2.[2..24],
reject_rhsbl_helo XXXXXXXXXXXXXXX.zrd.dq.spamhaus.net=127.0.2.[2..24],
reject_rhsbl_reverse_client XXXXXXXXXXXXXXX.zrd.dq.spamhaus.net=127.0.2.[2..24],
reject_rbl_client XXXXXXXXXXXXXXX.zen.dq.spamhaus.net=127.0.0.[2..255]
rbl_reply_maps = hash:/opt/postfix/conf/dnsbl-reply-map
@[deleted] Hope it helps
@[deleted] is this okay or this the “wrong” approach and should be configured somewhere else?
