I am trying to update my installation and this is what I am getting:
root@mail:/opt/mailcow-dockerized# ./update.sh
Checking internet connection… OK
Detecting which build your mailcow runs on…
You are receiving stable updates (master).
To change that run the update.sh Script one time with the –nightly parameter to switch to nightly builds.
Checking for newer update script…
Updated 0 paths from cd297314
Great! Native IPv6 NAT is active.
Validating docker-compose stack configuration…
./update.sh: line 755: docker-compose: command not found
Oh no, something went wrong. Please check the error message above.
I have Docker Compose version v2.12.2 installed. Running Ubuntu 22.04.1 LTS .
Very confused. Any help would be appreciated?
