Yes, will provide for you wait
English
after restore, sogo no mailbox selected
Here are the log
Hi, I am using backup and restore scripts, as mention on documentation
Alternatively, you can use the ./helper-scripts/backup_and_restore.sh script to create a full backup on the source machine, then install mailcow on the target machine as usual, copy over your mailcow.conf and use the same script to restore your backup to the target machine.
dns resolution is ok?
Regards,
Anyone that can help?
Thanks
update
suddenly the sogo and mailbox t works
i didn’t do anything
not sure what happen
hahahha
just check and as I expected,
the mailbox is works
hehehe
nothing to do from last check
hello , kann you tell me how do u have resolv’it ?
thanks in advace
riflandisch if the restore successful
Juat wait couple of days
And then it just works
I dont do anything, just wait couple of days and works / resolve by it self
I am not sure the problem is, but i think the certificate
Anyway i am not sure
Thanks
