Hello,
I have had my Mailcow server for about three years. I have not checked since then if TLSv1.3 is actually working, I just blindly assumed it was. Unfortunately, today I had to use the SSL Labs tool to find out that TLSv1.3 is not enabled.
My question is how can I enable TLSv1.3 and how can I check this not only for nginx but also for postfix and dovecot.
Any help would be appreciated.
Attached are the configuration files for nginx.
data/conf/nginx/site.conf
server {
listen 80 default_server;
if ( $request_uri ~* "%0A|%0D" ) { return 403; }
return 301 https://$host$uri$is_args$args;
server_tokens off;
proxy_cache_path /tmp levels=1:2 keys_zone=sogo:10m inactive=24h max_size=1g;
server_names_hash_bucket_size 64;
map $http_x_forwarded_proto $client_req_scheme {
default $scheme;
https https;
include /etc/nginx/conf.d/sites.active;
data/conf/nginx/includes/site-defaults.conf
include /etc/nginx/mime.types;
charset utf-8;
override_charset on;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers on;
ssl_ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA$
ssl_ecdh_curve X25519:X448:secp384r1:secp256k1;
ssl_session_timeout 1d;
ssl_session_tickets off;
add_header Strict-Transport-Security "max-age=15768000;";
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header X-Download-Options noopen;
add_header X-Frame-Options "SAMEORIGIN" always;
add_header X-Permitted-Cross-Domain-Policies none;
add_header Referrer-Policy strict-origin;
data/conf/nginx/wwwforward.conf
server {
ssl_certificate /etc/ssl/mail/cert.pem;
ssl_certificate_key /etc/ssl/mail/key.pem;
index index.php index.html;
client_max_body_size 0;
root /web;
include /etc/nginx/conf.d/listen_plain.active;
include /etc/nginx/conf.d/listen_ssl.active;
server_name smtp.* imap.* pop.* autoconfig.* autodiscover.*;
allow all;
default_type "text/plain";
location / {
return 301 https://mail.example.org/;
data/conf/nginx/webmail.conf
server {
root /web;
server_name webmail.*;
allow all;
location / {
return 301 https://mail.example.org/SOGo;
