Aliases messages no being counted.
If I create an alias for example “no-reply” for my main domain “support”, and I send using SMTP with no-reply, the outgoing emails not counted.
How can I count total outgoing messages using the API?
Please help,
How can i know how much total outgoing for a domain?
Or how to know for aliases?
Help still needed,
This is a massive security hole,
I can send an unlimited message if I create an alias for a mailbox
  • MAGIC
    • Forum Staff
    • volunteer
    Moolevel 48
Ah you mean for the ratelimit?
We can create an issue on GitHub for this if you want.
    MAGIC yes correct, we can’t detect number of total outgoing emails for alias/domain if alias created for a mailbox you will see only the mailbox total messages,
    It’s a hack, if you will create an alias for a mailbox, then use that alias for smtp to send messages you can’t track total outgoing email for that alias - i need help how can i track? Possible to change some where?
