diekuh Hi Diekuh, Yes, I setup a thunderbird to view the imap folder to see all mail stored in a Folder External, and I see the github have update for revised the EXTERNAL folder issue, after update and restart the container and re-create the sync rule again, the issue fixed, thank you so much for the developer for help.
