I got mailcow running for over a year behind traefik without any problems. But I’m still on the 1.7.x version of traefik as I had not found the time to migrate my configuration to v2.x, so configuration for v2.x might differ slightly!
These are my configurations:
The traefik_proxy network has to be added prior starting the containers, of course:
docker network create traefik_proxy
Traefiks docker-compose.yml:
version: '3'
services:
traefik:
hostname: traefik
image: traefik:1.7.24 # The official Traefik docker image
container_name: traefik
restart: always
domainname: mydomain.com
networks:
- default
- traefik_proxy
ports:
- "80:80" # The HTTP port
- "443:443" # The HTTPS port
volumes:
- /var/run/docker.sock:/var/run/docker.sock # So that Traefik can listen to the Docker events
- /opt/traefik/traefik.toml:/traefik.toml
- /opt/traefik/acme.json:/acme.json
environment:
- OVH_ENDPOINT=ovh-eu
- OVH_APPLICATION_KEY=MY_APPLICATION_KEY
- OVH_APPLICATION_SECRET=MY_APPLICATION_SECRET
- OVH_CONSUMER_KEY=MY_CONSUMER_KEY
labels:
- "traefik.enable=true"
- "traefik.backend=traefik:1.7.24"
- "traefik.frontend.rule=mydomain.com"
- "traefik.frontend.rule=Host:traefik.mydomain.com"
- "traefik.port=8081"
- "traefik.docker.network=traefik_proxy"
- "traefik.frontend.headers.SSLRedirect=true"
- "traefik.frontend.headers.STSSeconds=315360000"
- "traefik.frontend.headers.browserXSSFilter=true"
- "traefik.frontend.headers.contentTypeNosniff=true"
- "traefik.frontend.headers.forceSTSHeader=true"
- "traefik.frontend.headers.SSLHost=mydomain.com"
- "traefik.frontend.headers.STSIncludeSubdomains=true"
- "traefik.frontend.headers.STSPreload=true"
- "traefik.frontend.headers.frameDeny=true"
- "traefik.frontend.auth.basic.users=admin:PASSWORDHASH"
networks:
traefik_proxy:
external:
default:
driver: bridge
Traefiks rules.toml:
[frontends]
[frontends.frontend1.redirect]
entryPoint = "https"
regex=^https?://webmail.mydomain.com/(.*)
replacement=https:/mail.mydomain.com/SOGo/$${1}
permanent = true
[entryPoints]
[entryPoints.http]
address = ":80"
[entryPoints.http.redirect]
Mailcows docker-compose.override.yml:
version: '2.1'
services:
nginx-mailcow:
expose:
- "8080"
labels:
- "traefik.backend=nginx-mailcow"
- "traefik.frontend.rule=Host:${MAILCOW_HOSTNAME}"
- "traefik.port=8080"
networks:
- traefik_proxy
networks:
traefik_proxy:
external:
default:
driver: bridge
Mailcows mailcow.conf:
# mailcow web ui configuration
# example.org is _not_ a valid hostname, use a fqdn here.
# Default admin user is "admin"
# Default password is "moohoo"
MAILCOW_HOSTNAME=mail.mydomain.com
# SQL database configuration
DBNAME=mailcow
DBUSER=mailcow
# Please use long, random alphanumeric strings (A-Za-z0-9)
DBPASS=xxx
DBROOT=yyy
# HTTP/S Bindings
# You should use HTTPS, but in case of SSL offloaded reverse proxies:
HTTP_PORT=8080
HTTP_BIND=127.0.0.1
HTTPS_PORT=8443
HTTPS_BIND=127.0.0.1
#HTTP_PORT=80
#HTTP_BIND=0.0.0.0
#HTTPS_PORT=443
#HTTPS_BIND=0.0.0.0
# Other bindings
# You should leave that alone
# Format: 11.22.33.44:25 or 0.0.0.0:465 etc.
# Do _not_ use IP:PORT in HTTP(S)_BIND or HTTP(S)_PORT
SMTP_PORT=25
SMTPS_PORT=465
SUBMISSION_PORT=587
IMAP_PORT=143
IMAPS_PORT=993
POP_PORT=110
POPS_PORT=995
SIEVE_PORT=4190
DOVEADM_PORT=127.0.0.1:19991
SQL_PORT=127.0.0.1:13306
# Your timezone
TZ=Europe/Berlin
# Fixed project name
COMPOSE_PROJECT_NAME=mailcowdockerized
# Additional SAN for the certificate
ADDITIONAL_SAN=
# Skip running ACME (acme-mailcow, Let's Encrypt certs) - y/n
SKIP_LETS_ENCRYPT=n
# Skip IPv4 check in ACME container - y/n
SKIP_IP_CHECK=n
# Skip ClamAV (clamd-mailcow) anti-virus (Rspamd will auto-detect a missing ClamAV container) - y/n
SKIP_CLAMD=n
# Enable watchdog (watchdog-mailcow) to restart unhealthy containers (experimental)
USE_WATCHDOG=n
# Send notifications by mail (no DKIM signature, sent from watchdog@MAILCOW_HOSTNAME)
#WATCHDOG_NOTIFY_EMAIL=
# Max log lines per service to keep in Redis logs
LOG_LINES=9999
# Internal IPv4 /24 subnet, format n.n.n. (expands to n.n.n.0/24)
IPV4_NETWORK=172.22.1
# Internal IPv6 subnet in fc00::/7
IPV6_NETWORK=fd4d:6169:6c63:6f77::/64
# Use this IPv4 for outgoing connections (SNAT)
#SNAT_TO_SOURCE=
# Use this IPv6 for outgoing connections (SNAT)
#SNAT6_TO_SOURCE=
# Disable IPv6
# mailcow-network will still be created as IPv6 enabled, all containers will be created
# without IPv6 support.
# Use 1 for disabled, 0 for enabled
SYSCTL_IPV6_DISABLED=0
# Create or override API key for web uI
# You _must_ define API_ALLOW_FROM, which is a comma separated list of IPs
#API_KEY=
#API_ALLOW_FROM=127.0.0.1,1.2.3.4
# Garbage collector cleanup
# Deleted domains and mailboxes are moved to /var/vmail/_garbage/timestamp_sanitizedstring
# How long should objects remain in the garbage until they are being deleted? (value in minutes)
# Check interval is hourly
MAILDIR_GC_TIME=1440
# Set this to "allow" to enable the anyone pseudo user. Disabled by default.
# When enabled, ACL can be created, that apply to "All authenticated users"
# This should probably only be activated on mail hosts, that are used exclusivly by one organisation.
# Otherwise a user might share data with too many other users.
ACL_ANYONE=disallow
# Solr heap size, there is no recommendation, please see Solr docs.
# Solr is a prone to run OOM on large systems and should be monitored. Unmonitored Solr setups are not recommended.
# Solr will refuse to start with total system memory below or equal to 2 GB.
SOLR_HEAP=1024
# Solr is disabled by default after upgrading from non-Solr to Solr-enabled mailcows.
# Disable Solr or if you do not want to store a readable index of your mails in solr-vol-1.
SKIP_SOLR=n
# MAILDIR_SUB defines a path in a users virtual home to keep the maildir in. Leave empty for updated setups.
#MAILDIR_SUB=Maildir
MAILDIR_SUB=
ALLOW_ADMIN_EMAIL_LOGIN=n
SKIP_HTTP_VERIFICATION=n
# Notify about banned IP. Includes whois lookup.
WATCHDOG_NOTIFY_BAN=y
# SOGo session timeout in minutes
SOGO_EXPIRE_SESSION=480
# Create seperate certificates for all domains - y/n
# this will allow adding more than 100 domains, but some email clients will not be able to connect with alternative hostnames
# see https://wiki.dovecot.org/SSL/SNIClientSupport
ENABLE_SSL_SNI=n
# Checks if mailcow is an open relay. Requires a SAL. More checks will follow.
# No data is collected. Opt-in and anonymous.
# Will only work with unmodified mailcow setups.
WATCHDOG_EXTERNAL_CHECKS=n
REDIS_PORT=127.0.0.1:7654
in Mailcows docker-compose.yml I disabled the ports section used by nginx-mailcow:, because I did not knew a way of commenting something out via the override file:
# ports:
# - "${HTTPS_BIND:-0.0.0.0}:${HTTPS_PORT:-443}:${HTTPS_PORT:-443}"
# - "${HTTP_BIND:-0.0.0.0}:${HTTP_PORT:-80}:${HTTP_PORT:-80}"
