ETNyx LOL Yes I have never used AI. I used the open ai you recommended and gave it my logs and AI fixed it. Walked me through it like I had an instructor. Had to make a small change in Mailcow.conf as well. Basically Mailcow postfix and my smtp relay was having a fight with each other at least that’s how AI explained it to me lol. It told me to remove ufw and disable postfix and it fixed it. Also has a little issue with the ssl certificate with let’s encrypt and it fixed that too. It also successfully helped me remove my ip from that backlist.
Very surprised. Never thought it was this good.
I appreciate it and saved me from starting all over and or spending $$ for a pro to fix something I don’t understand.
I did like how it explained to me what each thing is actually supposed to do, so I am learning about it as well.
I will definitely use that AI again for my Mailcow.
Interestingly enough I decided to take my shot with my ISP and see if they can open my smtp outbound port 25 and they removed the restrictions. But AI told me to continue using my smtp relay and it would bypass the PTR that I don’t have because.
What your opinion, Do You think it’s worth it for me to try to get them to add a PTR for my server or would this just stir up issues with my ISP? I heard I can buy a static IP block but idk if this would help. Currently my ip has not changed in the 6 years I been with them. I currently have my router forwarding ports to my server and opnsense running in between my router and server for security.
