esackbauer Good idea, unfortunately it still fails
acme-mailcow-1 | Sun Nov 9 11:00:05 UTC 2025 - Initializing, please wait...
acme-mailcow-1 | Sun Nov 9 11:00:05 UTC 2025 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow-1 | Sun Nov 9 11:00:05 UTC 2025 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow-1 | Sun Nov 9 11:00:05 UTC 2025 - Detecting IP addresses...
acme-mailcow-1 | Sun Nov 9 11:00:05 UTC 2025 - OK: 5.75.244.224, 2a01:4f8:c17:58a7::1
acme-mailcow-1 | Sun Nov 9 11:00:05 UTC 2025 - Found AAAA record for autodiscover.usel.eu: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:06 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:06 UTC 2025 - Found AAAA record for autoconfig.usel.eu: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:07 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:07 UTC 2025 - Found AAAA record for mta-sts.usel.eu: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:08 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:09 UTC 2025 - Found AAAA record for autodiscover.usel.lu: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:10 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:10 UTC 2025 - Found AAAA record for autoconfig.usel.lu: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:11 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:11 UTC 2025 - Found AAAA record for mta-sts.usel.lu: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:12 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:12 UTC 2025 - Found AAAA record for autodiscover.usel.me: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:13 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:13 UTC 2025 - Found AAAA record for autoconfig.usel.me: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:14 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:14 UTC 2025 - Found AAAA record for mta-sts.usel.me: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:15 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:15 UTC 2025 - Found AAAA record for autodiscover.usel.ovh: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:16 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:17 UTC 2025 - Found AAAA record for autoconfig.usel.ovh: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:18 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:18 UTC 2025 - Found AAAA record for mta-sts.usel.ovh: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:19 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:19 UTC 2025 - Found AAAA record for hx2.usel.eu: 2a01:4f8:c17:58a7::1 - skipping A record check
acme-mailcow-1 | Sun Nov 9 11:00:20 UTC 2025 - Confirmed AAAA record with IP 2a01:04f8:0c17:58a7:0000:0000:0000:0001, but HTTP validation failed
acme-mailcow-1 | Sun Nov 9 11:00:20 UTC 2025 - Cannot validate any hostnames, skipping Let's Encrypt for 1 hour.
acme-mailcow-1 | Sun Nov 9 11:00:20 UTC 2025 - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
acme-mailcow-1 | OK
