I want to set up Mailcow with Nginx to listen on ports 80 and 443 but without interfering with any reverse proxy setup. Is it possible to create an Nginx config file for my other websites and then run docker-compose up -d, so my other websites will be live without needing to configure a reverse proxy for them? I also want to ensure SSL is set up for the my sites as well.
Is this achievable?
I’m not sure enough of this, but nginx container works with the mailcow docker network so even if i manage to host a site in nginx container it wont be able to my server localhost , end up not working, am i right ?
i never understand whenever i post a comment it says reload page something wrong happened but in the end it post multiple times
