Hi all!
I’ve also been updating Mailcow and have encountered the issue of postfix-tls-pol restarting repeatedly. No problem, of course, because there’s a solution for that, which is manually building the postfix-tlspol image.
So I’ve executed these troubleshooting commands suggested by the Mailcow team:
docker build -t ghcr.io/mailcow/postfix-tlspol:1.0 data/Dockerfiles/postfix-tlspol
docker compose up -d
Unfortunately, I have received the following error for that: ERROR: failed to solve: process "/bin/sh -c apt-get update && apt-get install -y --no-install-recommends \tca-certificates \tdirmngr \tdnsutils \tiputils-ping \tsudo \tsupervisor \tredis-tools \tsyslog-ng \tsyslog-ng-core \tsyslog-ng-mod-redis \ttzdata \t&& rm -rf /var/lib/apt/lists/* \t&& touch /etc/default/locale" did not complete successfully: exit code: 255
I’ve tried manually executing the commands Docker wanted to execute, but there’s no problem there. The output I’ve received is enclosed in this thread.
If anyone could help me with this issue, I would greatly appreciate it. ❤️
