Hi guys,
I’ve tried to update my machine to the latest version, but unbound doesn’t like to start anymore.
This is what I see in the logs:
docker compose logs unbound-mailcow
unbound-mailcow-1 | Setting console permissions…
unbound-mailcow-1 | Receiving anchor key…
unbound-mailcow-1 | Receiving root hints…
unbound-mailcow-1 | setup in directory /etc/unbound
unbound-mailcow-1 | Certificate request self-signature ok
unbound-mailcow-1 | subject=CN=unbound-control
unbound-mailcow-1 | removing artifacts
unbound-mailcow-1 | Setup success. Certificates created. Enable in unbound.conf file to use
unbound-mailcow-1 | 2025-09-11 12:35:20,834 INFO Set uid to user 0 succeeded
unbound-mailcow-1 | 2025-09-11 12:35:20,847 INFO supervisord started with pid 1
unbound-mailcow-1 | 2025-09-11 12:35:21,897 INFO spawned: ‘processes’ with pid 23
unbound-mailcow-1 | 2025-09-11 12:35:21,909 INFO spawned: ‘syslog-ng’ with pid 24
unbound-mailcow-1 | 2025-09-11 12:35:21,927 INFO spawned: ‘unbound’ with pid 25
unbound-mailcow-1 | 2025-09-11 12:35:21,932 INFO spawned: ‘unbound-healthcheck’ with pid 26
unbound-mailcow-1 | Sep 11 12:35:22 d3214f01cbe8 syslog-ng[24]: syslog-ng starting up; version=‘4.8.1’
unbound-mailcow-1 | [1757586922] unbound[25:0] notice: init module 0: subnetcache
unbound-mailcow-1 | [1757586922] unbound[25:0] notice: init module 1: validator
unbound-mailcow-1 | [1757586922] unbound[25:0] notice: init module 2: iterator
unbound-mailcow-1 | [1757586922] unbound[25:0] info: start of service (unbound 1.22.0).
unbound-mailcow-1 | 2025-09-11 12:35:23,110 INFO success: processes entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
unbound-mailcow-1 | 2025-09-11 12:35:23,110 INFO success: syslog-ng entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
unbound-mailcow-1 | 2025-09-11 12:35:23,110 INFO success: unbound entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
unbound-mailcow-1 | 2025-09-11 12:35:23,110 INFO success: unbound-healthcheck entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
unbound-mailcow-1 | [1757586925] unbound[25:0] info: generate keytag query _ta-4f66-9728. NULL IN
unbound-mailcow-1 | 2025-09-11 12:35:34: Healthcheck: Failed to ping 1.1.1.1 on attempt 1. Trying again…
unbound-mailcow-1 | 2025-09-11 12:35:46: Healthcheck: Failed to ping 1.1.1.1 on attempt 2. Trying again…
unbound-mailcow-1 | 2025-09-11 12:35:58: Healthcheck: Failed to ping 1.1.1.1 on attempt 3. Trying again…
unbound-mailcow-1 | 2025-09-11 12:35:58: Healthcheck: Couldn’t ping 1.1.1.1 after 3 attempts. Marking this IP as failed.
unbound-mailcow-1 | 2025-09-11 12:36:10: Healthcheck: Failed to ping 8.8.8.8 on attempt 1. Trying again…
unbound-mailcow-1 | 2025-09-11 12:36:22: Healthcheck: Failed to ping 8.8.8.8 on attempt 2. Trying again…
unbound-mailcow-1 | 2025-09-11 12:36:34: Healthcheck: Failed to ping 8.8.8.8 on attempt 3. Trying again…
unbound-mailcow-1 | 2025-09-11 12:36:34: Healthcheck: Couldn’t ping 8.8.8.8 after 3 attempts. Marking this IP as failed.
unbound-mailcow-1 | 2025-09-11 12:36:46: Healthcheck: Failed to ping 9.9.9.9 on attempt 1. Trying again…
unbound-mailcow-1 | 2025-09-11 12:36:58: Healthcheck: Failed to ping 9.9.9.9 on attempt 2. Trying again…
unbound-mailcow-1 | 2025-09-11 12:37:10: Healthcheck: Failed to ping 9.9.9.9 on attempt 3. Trying again…
unbound-mailcow-1 | 2025-09-11 12:37:10: Healthcheck: Couldn’t ping 9.9.9.9 after 3 attempts. Marking this IP as failed.
unbound-mailcow-1 | 2025-09-11 12:37:10: Healthcheck: Too many ping failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
unbound-mailcow-1 | 2025-09-11 12:37:14: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
This is very strange, because till version 2025-07 I never had any problems before. My server runs Mailcow only (no other services like VPN etc.) and is a KVM with Debian 13.
Anybody else here with the same problem or (even better) a possible solution?
Thank you!
