oke
many thanks
i will try
[unknown]
hello sir
can u help me
where i must running this script
Automatic update¶
An update script in your mailcow-dockerized directory will take care of updates.
Run the update script:
./update.sh
If it needs to, it will ask you how you wish to proceed. Merge errors will be reported. Some minor conflicts will be auto-corrected (in favour for the mailcow-dockerized repository code).
