Here is footage from user.
He is tapping the “new message” button, and nothing happens.
I will have hands on device this weekend, until then that’s all i got.
Sogo change log version 5.12.1 (2025-04-30) says
-ui: Change angular material to fix issues with Safari iOS 18+ (068f1f3)
-ui: Change angular material to fix issues with Safari iOS 18+ (07c7528)
I thought this was the culprit, but i couldn’t find anything about said issues.
So i’m might be wrong on that.
Will keep you informed.
Thanks
Found it
https://bugs.sogo.nu/view.php?id=6096
checks out
