kate Is it possible to rename a mailbox, through the admin gui ? For example.. if someone wants to change their email address but keep their existing email. User foo@example.com becomes known as “bar@example.com” , and doesn’t want to use the “foo@example.com” login or email address any longer, but does want keep their email etc..
diekuh No. Not yet at least. A lot of stuff is involved. SOGo, ACLs, Sieve etc. I will probably create a script for it to be run as helper.
Cowboys_and_Angels Hi, what’s the status of renaming a mailbox? Common use case: marriage with name change ;-) A description what has to be done would be enough.
dPAutomation Hi, is there any script for renaming a mailbox as discussed here? I have to rename several mailboxes and it will be nice to have a solution.
kate MrScreemi You can move the directories within the dovecot vmail container (this keeps the email) . create a new user in the mailcow interface (or use the api) then get dovecot to recalculate the quota using doveadm mv /var/vmail/example.com/foo /var/vmail/example.net/bar Create user bar@example.net in gui interface doveadm quota recalc -u bar@example.net
