If you read the wall of text, I’ve written, I’m not against using WAFs or AV in general, but, thats the point you want to miss. 😉 (confirmation bias works in both directions) I also have to acknowledge that it’s a lot easier to find cases, where something went wrong instead of cases, where everything was working as it should (that’s not a good headline to begin with 😃) So I agree, that I’m biased, but not without reason. Just to make it clear, I would never suggest to rely on peoples common sense to prevent attacks, so I recommend usings WAFs and AVs, but - and that’s the important point here - these systems should not be taken for granted as the holy grail of protection. It’s just another layer of security…
Generally speaking a security concept needs to factor in a lot of things, including but not limited to attack vectors / attack surface. A WAFs / AVs benefit may outweigh the risks, but these risks have to be assessed as well. The main point in the discussion was not about, whether AVs / WAFs enhance security or lower security, but that SELinux is there for a reason, the same way AVs and WAFs are there. So I think, we both made our point. Everybody can do whatever he/she wants, but I will stay with SELinux as an additional layer. And as I found the solution to the aforementioned problem, there’s no need to disable it anymore.
