Hi all,
Ive upgraded today to the march update and was generally problematic. I could not connect to the domain, since it appears my VPN is banned since the upgrade.
In the logs following is visible too:
netfilter-mailcow-1 | Using IPTables backend
netfilter-mailcow-1 | Clearing all bans
netfilter-mailcow-1 | Traceback (most recent call last):
netfilter-mailcow-1 | File "/app/main.py", line 416, in <module>
netfilter-mailcow-1 | clear()
netfilter-mailcow-1 | File "/app/main.py", line 218, in clear
netfilter-mailcow-1 | tables.clearIPv4Table()
netfilter-mailcow-1 | File "/app/modules/IPTables.py", line 69, in clearIPv4Table
netfilter-mailcow-1 | self.clearTable(iptc.Table(iptc.Table.FILTER))
netfilter-mailcow-1 | File "/app/modules/IPTables.py", line 89, in clearTable
netfilter-mailcow-1 | filter_table.commit()
netfilter-mailcow-1 | File "/usr/lib/python3.12/site-packages/iptc/ip4tc.py", line 1612, in commit
netfilter-mailcow-1 | raise IPTCError("can't commit: %s" % (self.strerror()))
netfilter-mailcow-1 | iptc.ip4tc.IPTCError: can't commit: b'Resource temporarily unavailable'
Information to the setup:
- mailcow and using reverse proxy
- docker-compose.override.yml for mailcow (please see below)
- nginx-proxy auto gen nginx-proxy/nginx-proxy
docker-compose.override.yml:
services:
nginx-mailcow:
expose:
- "8080"
environment:
- VIRTUAL_HOST=${MAILCOW_HOSTNAME}
- LETSENCRYPT_HOST=${MAILCOW_HOSTNAME}
- LETSENCRYPT_MAIL=${MAILCOW_HOSTNAME}
- VIRTUAL_PROTO=http
- VIRTUAL_PORT=8080
volumes:
- /docker/nginx-proxy/data/certs/${MAILCOW_HOSTNAME}/fullchain.pem:/etc/ssl/mail/cert.pem:ro
- /docker/nginx-proxy/data/certs/${MAILCOW_HOSTNAME}/key.pem:/etc/ssl/mail/key.pem:ro
networks:
mailcow-network:
aliases:
- nginx
proxy:
dovecot-mailcow:
volumes:
postfix-mailcow:
volumes:
networks:
mailcow-network:
aliases:
- postfix
proxy:
networks:
mailcow-network:
driver: bridge
driver_opts:
com.docker.network.bridge.name: br-mailcow
enable_ipv6: true
ipam:
driver: default
config:
- subnet: ${IPV4_NETWORK:-172.22.1}.0/24
- subnet: ${IPV6_NETWORK:-fd4d:6169:6c63:6f77::/64}
proxy:
external: true
