I can now start the mailcow instance on the new server, but I get this:
WARN[0000] volume "mailcowdockerized_sogo-web-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_rspamd-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_clamd-db-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_crypt-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_vmail-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_redis-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_mysql-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_mysql-socket-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_sogo-userdata-backup-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_vmail-index-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
WARN[0000] volume "mailcowdockerized_postfix-vol-1" already exists but was not created by Docker Compose. Use `external: true` to use an existing volume
For what I can see in other posts and so on, it’s just a warning and I should be able to safely ignore it… but.. is there a way to “upgrade” or recreate those volumes to avoid this warning? I guess I could delete completely the backup from the new server and start from scratch, but I would like to avoid transferring 100Gb of data if I can 😛
Edit: I tried with docker compose down -vand it removed the containers… I’m running the create_cold_standby.shscript again and see if everything works fine afterwards.
Edit2: that did delete the volumes but also from disk (I am not really very experienced with docker… so this was my newbie thing I guess?) the create_cold_standby.sh is replicating the whole installation again apparently…
