Hello,
Since applying 2025-03b this morning, the Nginx container keeps restarting.
Here is its logs:
nginx-mailcow-1 | 2025/04/07 11:15:13 [warn] 1#1: the "listen ... http2" directive is deprecated, use the "http2" directive instead in /etc/nginx/nginx.conf:134
nginx-mailcow-1 | nginx: [warn] the "listen ... http2" directive is deprecated, use the "http2" directive instead in /etc/nginx/nginx.conf:134
nginx-mailcow-1 | 2025/04/07 11:15:13 [emerg] 1#1: a duplicate default server for 0.0.0.0:80 in /etc/nginx/conf.d/redirect.conf:3
nginx-mailcow-1 | nginx: [emerg] a duplicate default server for 0.0.0.0:80 in /etc/nginx/conf.d/redirect.conf:3
Probably having an incidence on other services:
rspamd-mailcow-1 | 2025-04-07 10:54:39 #39(controller) <rznbhc>; map; http_map_error: error reading http://nginx:8081/forwardinghosts.php(172.22.1.10:8081): connection with http server terminated incorrectly: IO write error: Connection refused
rspamd-mailcow-1 | 2025-04-07 10:54:39 #39(controller) <oxhd99>; map; http_map_error: error reading http://nginx:8081/settings.php(172.22.1.10:8081): connection with http server terminated incorrectly: IO write error: Connection refused
What is running so far:
mathilde@mx:/opt/mailcow-dockerized$ sudo docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
bd1fd3188ffc ghcr.io/mailcow/watchdog:2.07 "/watchdog.sh" 8 minutes ago Up 7 minutes mailcowdockerized-watchdog-mailcow-1
f944b3900fdf ghcr.io/mailcow/acme:1.92 "/sbin/tini -g -- /s…" 8 minutes ago Up 7 minutes mailcowdockerized-acme-mailcow-1
dec991e489ac ghcr.io/mailcow/nginx:1.03 "/docker-entrypoint.…" 8 minutes ago Restarting (1) 59 seconds ago mailcowdockerized-nginx-mailcow-1
a20407d8a1c7 ghcr.io/mailcow/rspamd:2.1 "/docker-entrypoint.…" 8 minutes ago Up 7 minutes mailcowdockerized-rspamd-mailcow-1
4759a96e2973 mcuadros/ofelia:latest "/usr/bin/ofelia dae…" 8 minutes ago Up 8 minutes mailcowdockerized-ofelia-mailcow-1
ff5ac05ac480 ghcr.io/mailcow/postfix:1.80 "/docker-entrypoint.…" 8 minutes ago Up 7 minutes 0.0.0.0:25->25/tcp, [::]:25->25/tcp, 0.0.0.0:465->465/tcp, [::]:465->465/tcp, 0.0.0.0:587->587/tcp, [::]:587->587/tcp, 588/tcp mailcowdockerized-postfix-mailcow-1
547606090f2b ghcr.io/mailcow/dovecot:2.33 "/docker-entrypoint.…" 8 minutes ago Up 8 minutes 0.0.0.0:110->110/tcp, [::]:110->110/tcp, 0.0.0.0:143->143/tcp, [::]:143->143/tcp, 0.0.0.0:993->993/tcp, [::]:993->993/tcp, 0.0.0.0:995->995/tcp, [::]:995->995/tcp, 0.0.0.0:4190->4190/tcp, [::]:4190->4190/tcp, 127.0.0.1:19991->12345/tcp mailcowdockerized-dovecot-mailcow-1
7f966eeace8c ghcr.io/mailcow/phpfpm:1.93 "/docker-entrypoint.…" 8 minutes ago Up 8 minutes 9000/tcp mailcowdockerized-php-fpm-mailcow-1
3504fdc83ccc mariadb:10.11 "docker-entrypoint.s…" 8 minutes ago Up 8 minutes 127.0.0.1:13306->3306/tcp mailcowdockerized-mysql-mailcow-1
412c12427ec8 redis:7.4.2-alpine "/bin/sh /redis-conf…" 8 minutes ago Up 8 minutes 127.0.0.1:7654->6379/tcp mailcowdockerized-redis-mailcow-1
af97c1e41a28 ghcr.io/mailcow/clamd:1.70 "/sbin/tini -g -- /c…" 8 minutes ago Up 7 minutes (healthy) mailcowdockerized-clamd-mailcow-1
3c8d18de234b ghcr.io/mailcow/netfilter:1.61 "/bin/sh -c /app/doc…" 8 minutes ago Up 8 minutes mailcowdockerized-netfilter-mailcow-1
734eed96e7bf ghcr.io/mailcow/unbound:1.24 "/docker-entrypoint.…" 8 minutes ago Up 8 minutes (healthy) 53/tcp, 53/udp mailcowdockerized-unbound-mailcow-1
1d612f870ec0 ghcr.io/mailcow/dockerapi:2.11 "/bin/sh /app/docker…" 8 minutes ago Up 8 minutes mailcowdockerized-dockerapi-mailcow-1
2890db447106 ghcr.io/mailcow/olefy:1.14 "python3 -u /app/ole…" 8 minutes ago Up 8 minutes mailcowdockerized-olefy-mailcow-1
ca7ce347aba9 memcached:alpine "docker-entrypoint.s…" 8 minutes ago Up 8 minutes 11211/tcp mailcowdockerized-memcached-mailcow-1
e9dc4f005aac ghcr.io/mailcow/sogo:1.133 "/docker-entrypoint.…" 8 minutes ago Up 8 minutes mailcowdockerized-sogo-mailcow-1
Some information regarding my very standard setup:
- No reverse proxy in front
- Debian 12.10
- Docker version 28.0.4, build b8034c0
- Docker Compose version v2.24.5
No modifications at all:
mathilde@mx:/opt/mailcow-dockerized$ sudo git diff
Thanks in advance for your help!
