shaneodoo
My rspamd.local.lua configuration file is welcome here.
Thank you for checking them out.
If I didn’t make a mistake when copying, it should be the unchanged original file. No changes have been made by us.
We use older Outlook versions as clients.
E.g. Outlook 2013 and 2016, connected via Active-Sync.
All Versions for 64-bit systems.
`rspamd_config.MAILCOW_AUTH = {
callback = function(task)
local uname = task:get_user()
if uname then
return 1
end
end
local monitoring_hosts = rspamd_config:add_map{
url = “/etc/rspamd/custom/monitoring_nolog.map”,
description = “Monitoring hosts”,
type = “regexp”
rspamd_config:register_symbol({
name = ‘SMTP_ACCESS’,
type = ‘postfilter’,
local util = require(“rspamd_util”)
local rspamd_logger = require “rspamd_logger”
local rspamd_ip = require ‘rspamd_ip’
local limited_access = task:get_symbol(“SMTP_LIMITED_ACCESS”)
if not uname then
return false
end
if not limited_access then
return false
end
local hash_key = 'SMTP_ALLOW_NETS_' .. uname
local redis_params = rspamd_parse_redis_server('smtp_access')
local ip = task:get_from_ip()
if ip == nil or not ip:is_valid() then
return false
end
local from_ip_string = tostring(ip)
smtp_access_table = {from_ip_string}
local maxbits = 128
local minbits = 32
if ip:get_version() == 4 then
maxbits = 32
minbits = 8
end
for i=maxbits,minbits,-1 do
local nip = ip:apply_mask(i):to_string() .. "/" .. i
table.insert(smtp_access_table, nip)
end
local function smtp_access_cb(err, data)
if err then
rspamd_logger.infox(rspamd_config, "smtp_access query request for ip %s>
return false
else
rspamd_logger.infox(rspamd_config, "checking ip %s for smtp_access in %>
for k,v in pairs(data) do
if (v and v ~= userdata and v == '1') then
rspamd_logger.infox(rspamd_config, "found ip in smtp_access map")
task:insert_result(true, 'SMTP_ACCESS', 0.0, from_ip_string)
return true
end
end
rspamd_logger.infox(rspamd_config, "couldnt find ip in smtp_access map")
task:insert_result(true, 'SMTP_ACCESS', 999.0, from_ip_string)
return true
end
end
table.insert(smtp_access_table, 1, hash_key)
local redis_ret_user = rspamd_redis_make_request(task,
redis_params, -- connect params
hash_key, -- hash key
false, -- is write
smtp_access_cb, --callback
'HMGET', -- command
smtp_access_table -- arguments
if not redis_ret_user then
rspamd_logger.infox(rspamd_config, "cannot check smtp_access redis map")
end
end,
priority = 10
name = ‘POSTMASTER_HANDLER’,
type = ‘prefilter’,
local rcpts = task:get_recipients(‘smtp’)
local lua_util = require “lua_util”
local from = task:get_from(1)
– not applying to mails with more than one rcpt to avoid bypassing filters b>
if rcpts and #rcpts == 1 then
for _,rcpt in ipairs(rcpts) do
local rcpt_split = rspamd_str_split(rcpt[‘addr’], ‘@’)
if #rcpt_split == 2 then
if rcpt_split[1] == ‘postmaster’ then
task:set_pre_result(‘accept’, ‘whitelisting postmaster smtp rcpt’)
return
end
end
end
end
if from then
for _,fr in ipairs(from) do
local fr_split = rspamd_str_split(fr[‘addr’], ‘@’)
if #fr_split == 2 then
if fr_split[1] == ‘postmaster’ and task:get_user() then
– no whitelist, keep signatures
task:insert_result(true, ‘POSTMASTER_FROM’, -2500.0)
return
end
end
end
end
end,
priority = 10
name = ‘KEEP_SPAM’,
type = ‘prefilter’,
if uname then
return false
end
local redis_params = rspamd_parse_redis_server('keep_spam')
return false
end
ip_check_table = {from_ip_string}
local maxbits = 128
local minbits = 32
maxbits = 32
minbits = 8
end
table.insert(ip_check_table, nip)
end
local function keep_spam_cb(err, data)
if err then
rspamd_logger.infox(rspamd_config, "keep_spam query request for ip %s r>
return false
else
rspamd_logger.infox(rspamd_config, "found ip in keep_spam map, sett>
task:set_pre_result('accept', 'ip matched with forward hosts')
end
end
end
end
table.insert(ip_check_table, 1, 'KEEP_SPAM')
'KEEP_SPAM', -- hash key
false, -- is write
keep_spam_cb, --callback
'HMGET', -- command
ip_check_table -- arguments
rspamd_logger.infox(rspamd_config, "cannot check keep_spam redis map")
end
end,
priority = 19
name = ‘TLS_HEADER’,
local tls_tag = task:get_request_header(‘TLS-Version’)
if type(tls_tag) == ‘nil’ then
task:set_milter_reply({
add_headers = {[‘X-Last-TLS-Session-Version’] = ‘None’}
else
add_headers = {[‘X-Last-TLS-Session-Version’] = tostring(tls_tag)}
end
end,
priority = 12
name = ‘TAG_MOO’,
local redis_params = rspamd_parse_redis_server(‘taghandler’)
local rspamd_http = require “rspamd_http”
local tagged_rcpt = task:get_symbol("TAGGED_RCPT")
local mailcow_domain = task:get_symbol("RCPT_MAILCOW_DOMAIN")
local function remove_moo_tag()
local moo_tag_header = task:get_header('X-Moo-Tag', false)
if moo_tag_header then
remove_headers = {['X-Moo-Tag'] = 0},
end
return true
end
if tagged_rcpt and tagged_rcpt[1].options and mailcow_domain then
local tag = tagged_rcpt[1].options[1]
rspamd_logger.infox("found tag: %s", tag)
local action = task:get_metric_action('default')
rspamd_logger.infox("metric action now: %s", action)
if action ~= 'no action' and action ~= 'greylist' then
rspamd_logger.infox("skipping tag handler for action: %s", action)
remove_moo_tag()
return true
end
local function http_callback(err_message, code, body, headers)
if body ~= nil and body ~= "" then
rspamd_logger.infox(rspamd_config, "expanding rcpt to \"%s\"", body)
local function tag_callback_subject(err, data)
if err or type(data) ~= 'string' then
rspamd_logger.infox(rspamd_config, "subject tag handler rcpt %s r<t %s returned invalid or empty data (\"%s\") or error (\"%s\") - trying subfollder tag handler...", body, data, err)
local function tag_callback_subfolder(err, data)
rspamd_logger.infox(rspamd_config, "subfolder tag handler for rcpt %s returned invalid or empty data (\"%s\") or error (\"%s\")", body, data, err)
remove_moo_tag()
else
rspamd_logger.infox("Add X-Moo-Tag header")
add_headers = {['X-Moo-Tag'] = 'YES'}
end
end
local redis_ret_subfolder = rspamd_redis_make_request(task,
body, -- hash key
false, -- is write
tag_callback_subfolder, --callback
'HGET', -- command
{'RCPT_WANTS_SUBFOLDER_TAG', body} -- arguments
if not redis_ret_subfolder then
rspamd_logger.infox(rspamd_config, "cannot make request to load>
remove_moo_tag()
end
else
rspamd_logger.infox("user wants subject modified for tagged mail")
local sbj = task:get_header('Subject')
new_sbj = '=?UTF-8?B?' .. tostring(util.encode_base64('[' .. tag .. '] ' .. sbj)) .. '?='
remove_headers = {
['Subject'] = 1,
['X-Moo-Tag'] = 0
add_headers = {['Subject'] = new_sbj}
end
end
local redis_ret_subject = rspamd_redis_make_request(task,
body, -- hash key
false, -- is write
tag_callback_subject, --callback
'HGET', -- command
{'RCPT_WANTS_SUBJECT_TAG', body} -- arguments
if not redis_ret_subject then
rspamd_logger.infox(rspamd_config, "cannot make request to load tag handler for rcpt")
remove_moo_tag()
end
end
end
local rcpt_split = rspamd_str_split(rcpt['addr'], '@')
if rcpt_split[1] == 'postmaster' then
rspamd_logger.infox(rspamd_config, "not expanding postmaster alias")
remove_moo_tag()
else
rspamd_http.request({
task=task,
url='http://nginx:8081/aliasexp.php',
body='',
callback=http_callback,
headers={Rcpt=rcpt['addr']},
end
end
end
end
else
remove_moo_tag()
end
end,
priority = 19
name = ‘BCC’,
local from_table = {}
local rcpt_table = {}
if task:has_symbol('ENCRYPTED_CHAT') then
return -- stop
end
local send_mail = function(task, bcc_dest)
local lua_smtp = require "lua_smtp"
local function sendmail_cb(ret, err)
if not ret then
rspamd_logger.errx(task, 'BCC SMTP ERROR: %s', err)
else
rspamd_logger.infox(rspamd_config, "BCC SMTP SUCCESS TO %s", bcc_dest)
end
end
if not bcc_dest then
return -- stop
end
-- dot stuff content before sending
local email_content = tostring(task:get_content())
email_content = string.gsub(email_content, "\r\n%.", "\r\n..")
-- send mail
lua_smtp.sendmail({
task = task,
host = os.getenv("IPV4_NETWORK") .. '.253',
port = 591,
from = task:get_from(stp)[1].addr,
recipients = bcc_dest,
helo = 'bcc',
timeout = 20,
}, email_content, sendmail_cb)
end
-- determine from
local from = task:get_from('smtp')
if from then
for _, a in ipairs(from) do
table.insert(from_table, a['addr']) -- add this rcpt to table
table.insert(from_table, '@' .. a['domain']) -- add this rcpts domain t>
end
else
return -- stop
end
-- determine rcpts
local rcpts = task:get_recipients('smtp')
if rcpts then
for _, a in ipairs(rcpts) do
table.insert(rcpt_table, a['addr']) -- add this rcpt to table
table.insert(rcpt_table, '@' .. a['domain']) -- add this rcpts domain t>
end
else
return -- stop
end
local function rcpt_callback(err_message, code, body, headers)
if err_message == nil and code == 201 and body ~= nil then
if action == 'no action' or action == 'add header' or action == 'rewrite subject' then
send_mail(task, body)
end
end
end
local function from_callback(err_message, code, body, headers)
end
end
end
if rcpt_table then
for _,e in ipairs(rcpt_table) do
rspamd_logger.infox(rspamd_config, "checking bcc for rcpt address %s", e)
task=task,
url='http://nginx:8081/bcc.php',
body='',
callback=rcpt_callback,
headers={Rcpt=e}
end
end
if from_table then
for _,e in ipairs(from_table) do
rspamd_logger.infox(rspamd_config, "checking bcc for from address %s", e)
task=task,
callback=from_callback,
headers={From=e}
end
end
return true
end,
priority = 20
name = ‘DYN_RL_CHECK’,
type = ‘prefilter’,
local redis_params = rspamd_parse_redis_server(‘dyn_rl’)
local envfrom = task:get_from(1)
if not envfrom or not uname then
return false
end
local uname = uname:lower()
local env_from_domain = envfrom[1].domain:lower() -- get smtp from domain i>
local function redis_cb_user(err, data)
rspamd_logger.infox(rspamd_config, "dynamic ratelimit request for user >
local function redis_key_cb_domain(err, data)
rspamd_logger.infox(rspamd_config, "dynamic ratelimit request for d>
else
rspamd_logger.infox(rspamd_config, "found dynamic ratelimit in redi>
task:insert_result('DYN_RL', 0.0, data, env_from_domain)
end
end
local redis_ret_domain = rspamd_redis_make_request(task,
env_from_domain, -- hash key
false, -- is write
redis_key_cb_domain, --callback
'HGET', -- command
{'RL_VALUE', env_from_domain} -- arguments
if not redis_ret_domain then
rspamd_logger.infox(rspamd_config, "cannot make request to load ratelimit for domain")
end
else
rspamd_logger.infox(rspamd_config, "found dynamic ratelimit in redis for user %s with value %s", uname, data)
task:insert_result('DYN_RL', 0.0, data, uname)
end
end
uname, -- hash key
false, -- is write
redis_cb_user, --callback
'HGET', -- command
{'RL_VALUE', uname} -- arguments
rspamd_logger.infox(rspamd_config, "cannot make request to load ratelimit>
end
return true
end,
flags = ‘empty’,
priority = 20
name = ‘NO_LOG_STAT’,
local from = task:get_header(‘From’)
if from and (monitoring_hosts:get_key(from) or from == “watchdog@localhost”) then
task:set_flag(‘no_log’)
task:set_flag(‘no_stat’)
end
end
name = ‘MOO_FOOTER’,
type = ‘prefilter’,
local cjson = require “cjson”
local lua_mime = require “lua_mime”
return false
end
local env_from_addr = envfrom[1].addr:lower()
-- determine newline type
local function newline(task)
local t = task:get_newlines_type()
if t == 'cr' then
return '\r'
elseif t == 'lf' then
return '\n'
end
return '\r\n'
end
-- retrieve footer
local function footer_cb(err_message, code, data, headers)
rspamd_logger.infox(rspamd_config, "domain wide footer request for user %s returned invalid or empty data (\"%s\") or error (\"%s\")", uname, data, err)
else
-- parse json string
local footer = cjson.decode(data)
if not footer then
rspamd_logger.infox(rspamd_config, "parsing domain wide footer for user %s returned invalid or empty data (\"%s\") or error (\"%s\")", uname, data, err)
else
if footer and type(footer) == "table" and (footer.html and footer.htmml ~= "" or footer.plain and footer.plain ~= "") then
rspamd_logger.infox(rspamd_config, "found domain wide footer for user %s: html=%s, plain=%s, vars=%s", uname, footer.html, footer.plain, footer.vars)
if footer.skip_replies ~= 0 then
in_reply_to = task:get_header_raw('in-reply-to')
if in_reply_to then
rspamd_logger.infox(rspamd_config, "mail is a reply - skip footer")
return
end
end
local envfrom_mime = task:get_from(2)
local from_name = ""
if envfrom_mime and envfrom_mime[1].name then
from_name = envfrom_mime[1].name
elseif envfrom and envfrom[1].name then
from_name = envfrom[1].name
end
-- default replacements
local replacements = {
auth_user = uname,
from_user = envfrom[1].user,
from_name = from_name,
from_addr = envfrom[1].addr,
-- add custom mailbox attributes
if footer.vars and type(footer.vars) == "string" then
local footer_vars = cjson.decode(footer.vars)
if type(footer_vars) == "table" then
for key, value in pairs(footer_vars) do
replacements[key] = value
end
end
end
if footer.html and footer.html ~= "" then
footer.html = lua_util.jinja_template(footer.html, replacements, true)
end
if footer.plain and footer.plain ~= "" then
footer.plain = lua_util.jinja_template(footer.plain, replacements, true)
end
-- add footer
local out = {}
local rewrite = lua_mime.add_text_footer(task, footer.html, footer.plain) or {}
local seen_cte
local newline_s = newline(task)
local function rewrite_ct_cb(name, hdr)
if rewrite.need_rewrite_ct then
if name:lower() == 'content-type' then
-- NEW: include boundary if present
local boundary_part = rewrite.new_ct.boundary and
string.format('; boundary="%s"', rewrite.new_ct.boundary) or ''
local nct = string.format('%s: %s/%s; charset=utf-8%s',
'Content-Type', rewrite.new_ct.type, rewrite.new_ct.subtype, boundary_part)
out[#out + 1] = nct
-- update Content-Type header (include boundary if present)
remove_headers = {['Content-Type'] = 0},
add_headers = {['Content-Type'] = string.format('%s/%s; charset=utf-8%s',
rewrite.new_ct.type, rewrite.new_ct.subtype, boundary_part)}
return
elseif name:lower() == 'content-transfer-encoding' then
out[#out + 1] = string.format('%s: %s',
'Content-Transfer-Encoding', 'quoted-printable')
-- update Content-Transfer-Encoding header
remove_headers = {['Content-Transfer-Encoding'] = 0},
add_headers = {['Content-Transfer-Encoding'] = 'quoted-printable'}
seen_cte = true
return
end
end
out[#out + 1] = hdr.raw:gsub('\r?\n?$', '')
end
-- End of headers
out[#out + 1] = newline_s
if rewrite.out then
for _,o in ipairs(rewrite.out) do
out[#out + 1] = o
end
else
out[#out + 1] = task:get_rawbody()
end
local out_parts = {}
for _,o in ipairs(out) do
if type(o) ~= 'table' then
out_parts[#out_parts + 1] = o
out_parts[#out_parts + 1] = newline_s
else
local removePrefix = "--\x0D\x0AContent-Type"
if string.lower(string.sub(tostring(o[1]), 1, string.len(removePrefix))) == string.lower(removePrefix) then
o[1] = string.sub(tostring(o[1]), string.len("--\x0D\x0A") + 1)
end
out_parts[#out_parts + 1] = o[1]
if o[2] then
end
end
end
task:set_message(out_parts)
else
rspamd_logger.infox(rspamd_config, "domain wide footer request for user %s returned invalid or empty data (\"%s\")", uname, data)
end
end
end
end
-- fetch footer
task=task,
url='http://nginx:8081/footer.php',
body='',
callback=footer_cb,
headers={Domain=env_from_domain,Username=uname,From=env_from_addr},
return true
end,
priority = 1
shaneodoo
First of all, thank you so much for your hard work and care! I’m sorry, I’m still getting used to the world of Debian.
I haven’t got it right yet.
I inserted your rspamd.local.lua and restarted the Docker.
The result is almost perfect!
Nice!
A forwarded email with attachments includes the footer!
RspamD can handle the mail. It can read the sender, recipient and IP!
The attachments are also forwarded.
But!
If the forwarded email contains attachments and a screen clipping, the footer is attached, but the attachments disappear.
They are simply deleted.
If that is fixed the footer would be just perfect!
