Has anyone else seen this since updating to iOS 18.4? I can’t sync contacts or calendar with mailcow/SOGo. Every sync attempt comes up with an incorrect password. Other apps like BusyCal and 2do still work fine. Mac still works fine. Just iOS native access. I’ve tried deleting the accounts and re-adding but no joy!
Initially I saw a couple of 401s in the SOGo log but now not even seeing any attempts from my phone.
    basicmonkey I’ve tried deleting the accounts and re-adding but no joy!
    Did you add them with a separate App Password?
      esackbauer I’m not sure how you mean. I’ve never seen any app passwords for mailcow. Only ever used mailbox passwords.
      It just seems strange that the iPhone native client is not appearing at all in the SOGo logs. May be a URL parsing issue in the 18.4 update? I’ve tried setting all the usual possibilities: https://server/SOGo/dav/
      , https://server/SOGo/dav/user@domain
      server
      etc…
      Looks like I’ve found the issue. Following the nginx log I can see the username is URLencoded when others aren’t:
      10.10.20.108 - user%40domain [01/Apr/2025:14:24:57 +0100] “PROPFIND /SOGo/ HTTP/2.0” 401 172 “-” “iOS/18.4 (22E240) accountsd/1.0”
      [unknown] Thanks, I’ll give that a try. Looks like something has changed in 18.4 that changes the encoding of Cal/CardDAV usernames.
      [unknown] That works! Thank you. Interestingly it calls the correct user@domain as opposed to user%40domain that entering the details manually does. Definitely something changed in Apple world!
      I have the same issue. Ever since iOS 18.4 update CalDav stopped working. Seems an iOS bug. Not sure what to do besides wait for 18.4.1?
      Update: A user on Reddit figured out that by going into settings->mail->accounts->caldav account->advanced and in the user name deleting and re-adding the @ symbol fixed the issue.
      It worked for me!
