DerLinkman We even tell you to do during update.sh now 🙂
That would be really nice, but I don’t see any notification while running the update.sh script on my testcow (updating from 2025-02 to 2025-03):
root@testcow:/opt/mailcow-dockerized# ./update.sh
Detecting if your IP is listed on Spamhaus Bad ASN List...
Check completed! Your IP is clean
Detecting which build your mailcow runs on...
You are receiving stable updates (master).
To change that run the update.sh Script one time with the --nightly parameter to switch to nightly builds.
Updated 0 paths from aa7a4176
Are you sure you want to update mailcow: dockerized? All containers will be stopped. [y/N]
Where should I find the notification about the changelog? I hope it’s not AFTER confirming here 🙂
EDIT: OK, it’s after confirming, but then you have to confirm again, great work, thanks 🙂
MAJOR UPDATES to be applied:
2025-03 - https://github.com/mailcow/mailcow-dockerized/releases/tag/2025-03
Please read the release notes before proceeding.
Do you want to proceed with the update? [y/n]
