• MMaago
      Moolevel 7
    Hello,
    I set up the nightly build with LDAP integration because this is very important to me.
    In the setup I set the attribute to “employeetype” and connected 2 mail templates to the attribute values.
    In LDAP I created this attribute “employeeType” for each user and filled with either “default” or “removed”.
    The mailboxes for new users are created correct, but for existing users the cron log tells me:
    No matching attribute mapping found for user nnnn
    And this is for all users.
    I mapped all users to “LDAP” identity provider.
    Any idea what goes wrong?
    4 days later
    • SSaleh
        Moolevel 0
      I have the same issue on the latest stable MailCow version.
      MailCow LDAP Integration
      We have created a new “Identity Provider” using LDAP. The mailboxes for new users are created correct but the update for existing users or new created users not working. In the “Crontasks” logs we found the below log message:
      No matching attribute mapping found for user xxxx
      The above log message appears for the existing users and new created users.
      Thank you.
