Hi there,
I have the exact same issue on a fresh and up to date install, no firewall. @xavier, did you find any solution?
Here is the logs of mailcowdockerized_acme-mailcow_1
Sun Feb 21 17:56:43 CET 2021 - Detecting IP addresses...
Sun Feb 21 17:57:05 CET 2021 - OK: AAAA.BBBB.CCCC.DDDD, 0000:0000:0000:0000:0000:0000:0000:0000
Sun Feb 21 17:57:09 CET 2021 - Found AAAA record for mail.example.com: XXXX:YYYY:ZZZZ:000::1111 - skipping A record check
Sun Feb 21 17:57:09 CET 2021 - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname mail.example.com (DNS returned XXXX:YYYY:ZZZZ:000::1111)
Sun Feb 21 17:57:09 CET 2021 - Cannot validate any hostnames, skipping Let's Encrypt for 1 hour.
Sun Feb 21 17:57:09 CET 2021 - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
OK
Please note AAAA.BBBB.CCCC.DDDD
is the correct IPv4 of my server and XXXX:YYYY:ZZZZ:000::1111
is its correct IPv6.
So it appears the local IPv6 detection isn’t working as expected (0000:0000:0000:0000:0000:0000:0000:0000 is obviously wrong). IPv4 detection works fine:
As @xavier, everything else works just fine.
The issue has been reported on Github as well but without a fix: mailcow/mailcow-dockerized3897
For the record:
$ uname -a
Linux xxxxx 4.19.0-14-cloud-amd64 #1 SMP Debian 4.19.171-2 (2021-01-30) x86_64 GNU/Linux
$ sudo iptables -L -vn
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy DROP 0 packets, 0 bytes)
34358 13M DOCKER-USER all -- * * 0.0.0.0/0 0.0.0.0/0
34358 13M DOCKER-ISOLATION-STAGE-1 all -- * * 0.0.0.0/0 0.0.0.0/0
28295 11M ACCEPT all -- * br-mailcow 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
2519 157K DOCKER all -- * br-mailcow 0.0.0.0/0 0.0.0.0/0
3544 1554K ACCEPT all -- br-mailcow !br-mailcow 0.0.0.0/0 0.0.0.0/0
2511 156K ACCEPT all -- br-mailcow br-mailcow 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT all -- * docker0 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
0 0 DOCKER all -- * docker0 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT all -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT all -- docker0 docker0 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Chain DOCKER (2 references)
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.249 tcp dpt:6379
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.3 tcp dpt:8983
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.10 tcp dpt:3306
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:12345
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:4190
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.12 tcp dpt:587
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:995
2 100 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.12 tcp dpt:465
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:993
1 60 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.12 tcp dpt:25
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:143
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:110
3 160 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.13 tcp dpt:443
2 100 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.13 tcp dpt:80
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.5 tcp dpt:5443
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.5 tcp dpt:5269
0 0 ACCEPT tcp -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.5 tcp dpt:5222
3544 1554K DOCKER-ISOLATION-STAGE-2 all -- br-mailcow !br-mailcow 0.0.0.0/0 0.0.0.0/0
0 0 DOCKER-ISOLATION-STAGE-2 all -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
68130 33M RETURN all -- * * 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-ISOLATION-STAGE-2 (2 references)
0 0 DROP all -- * br-mailcow 0.0.0.0/0 0.0.0.0/0
0 0 DROP all -- * docker0 0.0.0.0/0 0.0.0.0/0
8708 7140K RETURN all -- * * 0.0.0.0/0 0.0.0.0/0
# Warning: iptables-legacy tables present, use iptables-legacy to see them
