@DocFraggle oFraggle I think you are right. I should have posted the logs here. The group here is always supportive and provide solutions. I was to quick to find a solution (and perhaps unfairly judged Mailcow too quickly) I will install it again soon and get it up and running again. I like Mailcow. Only a few hours and I already miss seeing the fat yellow cow. I think I didn’t disabled ufw completely. I will be back to Mailcow in two days.
The other software has a section on the main admin portal where you issue the cert and reload it and restart it and it is up and running. It even has a section that you can select when to autorenew (30 days or 10 days).
I usually install fail2ban and ufw per the instructions I followed from Opentaq (https://youtu.be/_z6do5BSJmg?si=_YUnnZY4uuVIMyhO). Maybe I need to follow a different tutorial. Please post any suggestions.
I will be back to Mailcow soon and if I run into any issues I will post here. I am even thinking of deleting this post because Mailcow is great and I don’t want to discourage others from using it.
Thanks!
