Greetings!
I want to write an nginx configuration for my mail server. Where to write it. What I am trying to achieve:
Suppose my admin panel is deployed on mail.example.com . This means that SOGO would be accessible on mail.example.com/SOGOand Roundcube(which I have already configured) would be accessible on mail.example.com/rc . So now I want to change the url or of my Roundcube panel. I want it to be webmail.example.com . How to achieve this goal. One thing I did was to declare configuration of my webmail.example.com at this path /opt/mailcow-dockerized/data/config/ngnix . It served the purpose for HTTP request but not for HTTPS, as it was not able to find the relevant ssl certificates.
Your help would be highly appreciated.
Regards
DocFraggle Thank you for your reply. I have one more question, what should I do about ssl certificates. I use Lets Encrypt ssl generation using certbot command. Do I need to store SSL certificates in a particular directory or inside this /etc/ssl/mail directory
