I get a lot of Replies on my emails, and I want to be able to access all of them at once, and the encryption and compression are a headache for me at the moment. Is there any way I can store the emails without encryption and compression? If yes, kindly elaborate your solution since I’m not very used to the mailcow SMTP service yet.
Thanks a lot for everyone willing to contribute to this. Thanks
  • EETNyx
      Moolevel 79
    Please elaborate, I do not understand why regular access (let’s say using IMAP) is not sufficient. Encryption and compression is implemented that way you do not know it’s there is regular situation,…
      ETNyx
      Sorry for not being clear.
      I want a solution where I can bulk import the email replies, since I have a lot of mailboxes and I do not want to go through all of them manually and read individual replies, I want to gather all replies, subjects, contents, senders etc in bulk if possible. I can further sort them on my own,
      Actually, I get a lot of email replies, which I need to scrap and get the content out of them. Could you help me with a way on how I can bulk import all replies? in decrypted format? Or I can set something which stops the encryption in the first place.
      • EETNyx
          Moolevel 79
        Sorry, not sure if your reply shed some light on your request,… Why you can’t use for this standard IMAP and SMTP protocol? From what I was able to catch from your description you will need, or you are doing some programing for this anyway, so just use IMAP/SMTP library, depending on your programing language of choose and you do not need to worry about how MailCow encrypt message on background.
          ETNyx
          I have written some scripts that do this decryption and manual work for me. So, that is working for me now.
          And thanks for the suggestion, but it was not what i was looking for.
          Still Bundle of thanks for your time
