Yes, even I can’t contact your server, I can ping so I would guess some firewall is blocking our communication.
Also you are missing PTR record for your IP, you need to fix this ASAP to run mailserver. Missing PTR is also reason why your IP is already on blacklist,…
EDIT: also take in consideration that it’s posiible this firewall is not yours but yours IPS,..
