Hello,
Just installed MailCow, I’m trying to move all notification services previously attached to a GMail account,
I have trouble with an HP LaerJet Pro M428dw.
It seems I can only use an authenticated connection,
I first tried on port 465 with “Always use SSL/TLS” but later I think I tried all options with no success.
The printer cannot send test email.
From what I understand the printer try to use a possibly outdated cipher.
postfix-mailcow-1  | Jan 30 18:30:52 ebcfb4003597 postfix/smtps/smtpd[353]: connect from unknown[10.x.y.z]
postfix-mailcow-1  | Jan 30 18:30:52 ebcfb4003597 postfix/smtps/smtpd[353]: SSL_accept error from unknown[10.x.y.z]: -1
postfix-mailcow-1  | Jan 30 18:30:52 ebcfb4003597 postfix/smtps/smtpd[353]: warning: TLS library problem: error:0A0000C1:SSL routines::no shared cipher:../ssl/statem/statem_srvr.c:2220:
postfix-mailcow-1  | Jan 30 18:30:52 ebcfb4003597 postfix/smtps/smtpd[353]: lost connection after CONNECT from unknown[10.x.y.z]
postfix-mailcow-1  | Jan 30 18:30:52 ebcfb4003597 postfix/smtps/smtpd[353]: disconnect from unknown[10.x.y.z] commands=0/0
Any idea?
DocFraggle
I tried this: docs.mailcow.email Icon Re-enable TLS 1.0 and TLS 1.1 - mailcow: dockerized documentation
but wasn’t enough.
I’m not happy to soften to every client in the world, but I could do if it is possible for just some ip…
With TLS 1.0 and 1.1 re-enabled MailCow accept this:
465/tcp open  smtps
| ssl-enum-ciphers:
|   TLSv1.0:
|     ciphers:
|       TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (ecdh_x25519) - A
|     compressors:
|       NULL
|     cipher preference: server
|   TLSv1.1:
|     ciphers:
|     compressors:
|       NULL
|   TLSv1.2:
|     ciphers:
|       TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_256_CCM_8 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_256_CCM (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_ARIA_256_GCM_SHA384 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_CCM_8 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_CCM (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_ARIA_128_GCM_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256 (ecdh_x25519) - A
|     compressors:
|       NULL
|   TLSv1.3:
|     ciphers:
|       TLS_AKE_WITH_AES_256_GCM_SHA384 (ecdh_x25519) - A
|       TLS_AKE_WITH_CHACHA20_POLY1305_SHA256 (ecdh_x25519) - A
|       TLS_AKE_WITH_AES_128_GCM_SHA256 (ecdh_x25519) - A
|_  least strength: A
On the other hand, GMail accept this:
465/tcp open  smtps
| ssl-enum-ciphers:
|   TLSv1.0:
|     ciphers:
|       TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (ecdh_x25519) - A
|       TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (ecdh_x25519) - A
|       TLS_RSA_WITH_AES_128_CBC_SHA (rsa 2048) - A
|       TLS_RSA_WITH_AES_256_CBC_SHA (rsa 2048) - A
|       TLS_RSA_WITH_3DES_EDE_CBC_SHA (rsa 2048) - C
|     compressors:
|       NULL
|     warnings:
|       64-bit block cipher 3DES vulnerable to SWEET32 attack
|   TLSv1.1:
|     ciphers:
|     compressors:
|       NULL
|     warnings:
|   TLSv1.2:
|     ciphers:
|       TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (ecdh_x25519) - A
|       TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (ecdh_x25519) - A
|       TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 (ecdh_x25519) - A
|       TLS_RSA_WITH_AES_128_GCM_SHA256 (rsa 2048) - A
|       TLS_RSA_WITH_AES_256_GCM_SHA384 (rsa 2048) - A
|     compressors:
|       NULL
|     cipher preference: client
|     warnings:
|   TLSv1.3:
|     ciphers:
|_  least strength: C
465/tcp open  smtps
| ssl-enum-ciphers:
|   TLSv1.0:
|     ciphers:
|     compressors:
|       NULL
|   TLSv1.1:
|     ciphers:
|     compressors:
|       NULL
|   TLSv1.2:
|     ciphers:
|     compressors:
|       NULL
|   TLSv1.3:
|     ciphers:
|_  least strength: A
465/tcp open  smtps
| ssl-enum-ciphers:
|   TLSv1.0:
|     ciphers:
|     compressors:
|       NULL
|     warnings:
|   TLSv1.1:
|     ciphers:
|     compressors:
|       NULL
|     warnings:
|   TLSv1.2:
|     ciphers:
|     compressors:
|       NULL
|     warnings:
|   TLSv1.3:
|     ciphers:
|_  least strength: C
  • esackbauer
    Moolevel 352
My advice: Don’t use encryption. Probably mailcow and the printer are in the same LAN anyway, and the notification does typically not include confidential data.
That leaves you only to use port 25, you cannot use authentication, then add the printer IP as “forwarding host”, and add it to the postscreen whitelist as well.
    • EETNyx
        Moolevel 47
      Well you can always spin up separate STMP server whit lower security. By this i mean just postfix just beside your printer, not directly facing internet (behind WAN), 20 EUR Raspberry Pi Zero will do just fine. This way you will not facing lower security server directly to internet and from there RPi will use authenticated relay to your proper mail as Mailcow.
      Or, I do not recommending this, because you can break future MC update,.. modify your master.conf and start another SMTP service on separate port whit lower security set up to only listen from your printer, possibly using VPN like WireGuard to bypass your ISP if you do not have static IP.
      And for ciphers suit there are other directives that you can tweak for postfix like smtpd_tls_ciphers, smtpd_tls_mandatory_ciphers, smtpd_tls_protocols, smtpd_tls_exclude_ciphers, smtpd_tls_ciphers, please refer to postfix docs
      And at last, be aware: Postfix relies on the system’s OpenSSL library for handling TLS/SSL connections. Therefore, the settings in openssl.conf can indirectly influence Postfix’s behavior, so you need to validate your Cipher suits look for CipherString also related MinProtocol, MaxProtocol, Options
      esackbauer It seems that with my “HP LaserJet Pro MFP M428dw” this doesn’t work despite the status of the checkbox “Always use secure connection (SSL/TLS)”?
      postfix/postscreen[2390]: CONNECT from [10.x.y.z]:59806 to [172.22.1.253]:25
      postfix/postscreen[2390]: ALLOWLISTED [10.x.y.z]:59806
      postfix/smtpd[2397]: connect from unknown[10.x.y.z]
      postfix/smtpd[2397]: lost connection after CONNECT from unknown[10.x.y.z]
      postfix/smtpd[2397]: disconnect from unknown[10.x.y.z] commands=0/0
      postfix/postscreen[2390]: CONNECT from [10.x.y.z]:59808 to [172.22.1.253]:25
      postfix/postscreen[2390]: ALLOWLISTED [10.x.y.z]:59808
      postfix/smtpd[2394]: connect from unknown[10.x.y.z]
      postfix/smtpd[2394]: SSL_accept error from unknown[10.x.y.z]: -1
      postfix/smtpd[2394]: warning: TLS library problem: error:0A0000C1:SSL routines::no shared cipher:../ssl/statem/statem_srvr.c:2220:
      postfix/smtpd[2394]: lost connection after STARTTLS from unknown[10.x.y.z]
      postfix/smtpd[2394]: disconnect from unknown[10.x.y.z] ehlo=1 starttls=0/1 commands=1/2
      • esackbauer
        Moolevel 352
      10.x.y.z is your printer? and you have disabled SSL/TLS and STARTTLS completely on the printer? Have you restarted the printer after that?
      HP printers are known to cause troubles due to faulty SMTP implementation (e.g. not sending FQDN in HELO string), the forum here has a lot posts regarding that.
      Maybe you find something useful.
        esackbauer yes, 10.x.y.z is my printer. I tried bot checking and unckecking the “Always use SSL” but there is still a problem. My understanding is that “Always use…” unchecked doens’t mean “never use”, so the printer still try encryption and fail.
        I searched the forum but the problems with HP seems a bit different than mine.
        I think I have to continue to use gmail for simplicity
