This is still not working
reverse DNS at the provider: 45.13.214.251 251.214.13.45.in-addr.arpa mail.barak-kalai.com
postfix logs
postfix-mailcow-1 | 2025-01-27 10:25:52,031 INFO Set uid to user 0 succeeded
postfix-mailcow-1 | 2025-01-27 10:25:52,034 INFO supervisord started with pid 1
postfix-mailcow-1 | 2025-01-27 10:25:53,038 INFO spawned: 'processes' with pid 8
postfix-mailcow-1 | 2025-01-27 10:25:53,042 INFO spawned: 'postfix' with pid 9
postfix-mailcow-1 | 2025-01-27 10:25:53,047 INFO spawned: 'syslog-ng' with pid 10
postfix-mailcow-1 | Uptime: 31 Threads: 6 Questions: 362 Slow queries: 0 Opens: 55 Open tables: 46 Queries per second avg: 11.677
postfix-mailcow-1 | Jan 27 10:25:53 4a70aeedf6c6 syslog-ng[10]: syslog-ng starting up; version='3.38.1'
postfix-mailcow-1 | Checking if ASN for your IP is listed for Spamhaus Bad ASN List...
postfix-mailcow-1 | 2025-01-27 10:25:54,635 INFO success: processes entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
postfix-mailcow-1 | 2025-01-27 10:25:54,635 INFO success: postfix entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
postfix-mailcow-1 | 2025-01-27 10:25:54,635 INFO success: syslog-ng entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
postfix-mailcow-1 | The AS of your IP is NOT listed as a banned AS from Spamhaus!
postfix-mailcow-1 | Using the open Spamhaus blocklists.
postfix-mailcow-1 | chown: cannot access '/usr/share/man/man1/mailq.1.gz': No such file or directory
postfix-mailcow-1 | Jan 27 10:25:57 4a70aeedf6c6 postfix/postfix-script[343]: starting the Postfix mail system
postfix-mailcow-1 | Jan 27 10:25:57 4a70aeedf6c6 postfix/master[345]: daemon started -- version 3.7.11, configuration /opt/postfix/conf
postfix-mailcow-1 | Jan 27 10:28:57 4a70aeedf6c6 postfix/postscreen[366]: cache proxy:btree:/var/lib/postfix/postscreen_cache full cleanup: retained=0 dropped=0 entries
postfix-mailcow-1 | Jan 27 10:28:57 4a70aeedf6c6 postfix/postscreen[366]: CONNECT from [10.7.0.1]:55579 to [172.22.1.253]:25
postfix-mailcow-1 | Jan 27 10:28:57 4a70aeedf6c6 whitelist_forwardinghosts: Look up 10.7.0.1 on whitelist, result 200 DUNNO
postfix-mailcow-1 | Jan 27 10:29:00 4a70aeedf6c6 postfix/postscreen[366]: PASS NEW [10.7.0.1]:55579
postfix-mailcow-1 | Jan 27 10:29:00 4a70aeedf6c6 postfix/smtpd[385]: connect from unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:29:01 4a70aeedf6c6 postfix/smtpd[385]: TLS SNI mail.barak-kalai.com from unknown[10.7.0.1] not matched, using default chain
postfix-mailcow-1 | Jan 27 10:29:01 4a70aeedf6c6 postfix/smtpd[385]: Anonymous TLS connection established from unknown[10.7.0.1]: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits) server-digest SHA256
postfix-mailcow-1 | Jan 27 10:29:02 4a70aeedf6c6 postfix/smtpd[385]: 4E922DA525: client=unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:29:02 4a70aeedf6c6 postfix/cleanup[387]: 4E922DA525: message-id=<CAGHNZE7k5=yt86_HXRMAnbpyanb0v7Kd3aOd2RcYeFCtNRrJYw@mail.gmail.com>
postfix-mailcow-1 | Jan 27 10:29:07 4a70aeedf6c6 postfix/cleanup[387]: 4E922DA525: milter-reject: END-OF-MESSAGE from unknown[10.7.0.1]: 4.7.1 Greylisted, please try again later; from=<barakkalai1@gmail.com> to=<barak@barak-kalai.com> proto=ESMTP helo=<mail-ed1-f44.google.com>
postfix-mailcow-1 | Jan 27 10:29:07 4a70aeedf6c6 postfix/smtpd[385]: disconnect from unknown[10.7.0.1] ehlo=2 starttls=1 mail=1 rcpt=1 data=0/1 quit=1 commands=6/7
postfix-mailcow-1 | Jan 27 10:30:12 4a70aeedf6c6 postfix/postscreen[366]: CONNECT from [10.7.0.1]:35269 to [172.22.1.253]:25
postfix-mailcow-1 | Jan 27 10:30:12 4a70aeedf6c6 whitelist_forwardinghosts: Look up 10.7.0.1 on whitelist, result 200 DUNNO
postfix-mailcow-1 | Jan 27 10:30:13 4a70aeedf6c6 postfix/postscreen[366]: PASS OLD [10.7.0.1]:35269
postfix-mailcow-1 | Jan 27 10:30:13 4a70aeedf6c6 postfix/smtpd[385]: connect from unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:30:13 4a70aeedf6c6 postfix/smtpd[385]: Anonymous TLS connection established from unknown[10.7.0.1]: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits) server-digest SHA256
postfix-mailcow-1 | Jan 27 10:30:15 4a70aeedf6c6 postfix/smtpd[385]: BA0EFDA525: client=unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:30:16 4a70aeedf6c6 postfix/cleanup[387]: BA0EFDA525: message-id=<0.0.E.DCE.1DB70D6A15B3BB2.0@mta-2d5b2df2.ip4.emsmtp.com>
postfix-mailcow-1 | Jan 27 10:30:19 4a70aeedf6c6 postfix/cleanup[387]: BA0EFDA525: milter-reject: END-OF-MESSAGE from unknown[10.7.0.1]: 4.7.1 Greylisted, please try again later; from=<suite57@bounces.mail-ext.movil.com.pa> to=<bkalai@barak-kalai.com> proto=ESMTP helo=<mta-2d5b2df2.ip4.emsmtp.com>
postfix-mailcow-1 | Jan 27 10:30:19 4a70aeedf6c6 postfix/smtpd[385]: disconnect from unknown[10.7.0.1] ehlo=2 starttls=1 mail=1 rcpt=1 data=0/1 quit=1 commands=6/7
postfix-mailcow-1 | Jan 27 10:33:21 4a70aeedf6c6 postfix/sogo/smtpd[398]: connect from mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network[172.22.1.248]
postfix-mailcow-1 | Jan 27 10:33:22 4a70aeedf6c6 postfix/sogo/smtpd[398]: B4E7ADA525: client=mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network[172.22.1.248], sasl_method=PLAIN, sasl_username=barak@barak-kalai.com
postfix-mailcow-1 | Jan 27 10:33:22 4a70aeedf6c6 postfix/cleanup[399]: B4E7ADA525: replace: header Received: from e8ee31e2428b (mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network [172.22.1.248])??(Authenticated sender: barak@barak-kalai.com)??by mail.barak-kalai.com (Postcow) with E from mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network[172.22.1.248]; from=<barak@barak-kalai.com> to=<barakkalai1@gmail.com> proto=ESMTP helo=<e8ee31e2428b>: Received: from [127.0.0.1] (localhost [127.0.0.1]) by localhost (Mailerdaemon) with ESMTPA id B4E7ADA525??for <barakkalai1@gmail.com>; Mon, 27 Jan 2025 10:33:21 -0600 (CST)
postfix-mailcow-1 | Jan 27 10:33:22 4a70aeedf6c6 postfix/cleanup[399]: B4E7ADA525: message-id=<143-6797b580-3-1ce1eb80@1612712>
postfix-mailcow-1 | Jan 27 10:33:23 4a70aeedf6c6 postfix/qmgr[347]: B4E7ADA525: from=<barak@barak-kalai.com>, size=909, nrcpt=1 (queue active)
postfix-mailcow-1 | Jan 27 10:33:23 4a70aeedf6c6 postfix/sogo/smtpd[398]: disconnect from mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network[172.22.1.248] ehlo=1 auth=1 mail=1 rcpt=1 data=1 quit=1 commands=6
postfix-mailcow-1 | Jan 27 10:33:23 4a70aeedf6c6 postfix/smtp[400]: Trusted TLS connection established to gmail-smtp-in.l.google.com[2607:f8b0:4023:1000::1b]:25: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature ECDSA (prime256v1) server-digest SHA256
postfix-mailcow-1 | Jan 27 10:33:24 4a70aeedf6c6 postfix/smtp[400]: B4E7ADA525: to=<barakkalai1@gmail.com>, relay=gmail-smtp-in.l.google.com[2607:f8b0:4023:1000::1b]:25, delay=2.8, delays=1.5/0.09/0.62/0.54, dsn=5.7.28, status=bounced (host gmail-smtp-in.l.google.com[2607:f8b0:4023:1000::1b] said: 550-5.7.28 [2602:fdb7:0:b30:cd0e:e361:88b9:1 1] Gmail has detected an 550-5.7.28 unusual rate of unsolicited mail originating from your IP address. 550-5.7.28 To protect our users from spam, mail sent from your IP address has 550-5.7.28 been blocked. For more information, go to 550-5.7.28 https://support.google.com/mail/?p=UnsolicitedIPError to review our 550 5.7.28 Bulk Email Senders Guidelines. 006d021491bc7-5fa8ba0cc96si6054991eaf.61 - gsmtp (in reply to end of DATA command))
postfix-mailcow-1 | Jan 27 10:33:24 4a70aeedf6c6 postfix/cleanup[402]: 8221CE4474: message-id=<20250127163324.8221CE4474@mail.barak-kalai.com>
postfix-mailcow-1 | Jan 27 10:33:24 4a70aeedf6c6 postfix/bounce[401]: B4E7ADA525: sender non-delivery notification: 8221CE4474
postfix-mailcow-1 | Jan 27 10:33:24 4a70aeedf6c6 postfix/qmgr[347]: 8221CE4474: from=<>, size=4496, nrcpt=1 (queue active)
postfix-mailcow-1 | Jan 27 10:33:24 4a70aeedf6c6 postfix/qmgr[347]: B4E7ADA525: removed
postfix-mailcow-1 | Jan 27 10:33:24 4a70aeedf6c6 postfix/lmtp[404]: 8221CE4474: to=<barak@barak-kalai.com>, relay=dovecot[fd4d:6169:6c63:6f77::a]:24, delay=0.19, delays=0.01/0.02/0.01/0.16, dsn=2.0.0, status=sent (250 2.0.0 <barak@barak-kalai.com> AGU4IVS1l2eyAAAAgPpuPA Saved)
postfix-mailcow-1 | Jan 27 10:33:24 4a70aeedf6c6 postfix/qmgr[347]: 8221CE4474: removed
postfix-mailcow-1 | Jan 27 10:33:39 4a70aeedf6c6 postfix/anvil[386]: statistics: max connection rate 1/60s for (smtpd:10.7.0.1) at Jan 27 10:29:00
postfix-mailcow-1 | Jan 27 10:33:39 4a70aeedf6c6 postfix/anvil[386]: statistics: max connection count 1 for (smtpd:10.7.0.1) at Jan 27 10:29:00
postfix-mailcow-1 | Jan 27 10:33:39 4a70aeedf6c6 postfix/anvil[386]: statistics: max cache size 1 at Jan 27 10:29:00
postfix-mailcow-1 | Jan 27 10:36:23 4a70aeedf6c6 postfix/postscreen[410]: CONNECT from [10.7.0.1]:54694 to [172.22.1.253]:25
postfix-mailcow-1 | Jan 27 10:36:23 4a70aeedf6c6 whitelist_forwardinghosts: Look up 10.7.0.1 on whitelist, result 200 DUNNO
postfix-mailcow-1 | Jan 27 10:36:24 4a70aeedf6c6 postfix/postscreen[410]: PASS OLD [10.7.0.1]:54694
postfix-mailcow-1 | Jan 27 10:36:24 4a70aeedf6c6 postfix/smtpd[430]: connect from unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:36:24 4a70aeedf6c6 postfix/smtpd[430]: TLS SNI mail.barak-kalai.com from unknown[10.7.0.1] not matched, using default chain
postfix-mailcow-1 | Jan 27 10:36:24 4a70aeedf6c6 postfix/smtpd[430]: Anonymous TLS connection established from unknown[10.7.0.1]: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits) server-digest SHA256
postfix-mailcow-1 | Jan 27 10:36:25 4a70aeedf6c6 postfix/smtpd[430]: 5EE4BDC36F: client=unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:36:25 4a70aeedf6c6 postfix/cleanup[432]: 5EE4BDC36F: message-id=<CAGHNZE7k5=yt86_HXRMAnbpyanb0v7Kd3aOd2RcYeFCtNRrJYw@mail.gmail.com>
postfix-mailcow-1 | Jan 27 10:36:27 4a70aeedf6c6 postfix/qmgr[347]: 5EE4BDC36F: from=<barakkalai1@gmail.com>, size=3264, nrcpt=1 (queue active)
postfix-mailcow-1 | Jan 27 10:36:27 4a70aeedf6c6 postfix/lmtp[433]: 5EE4BDC36F: to=<barak@barak-kalai.com>, relay=dovecot[172.22.1.250]:24, delay=2.3, delays=2.3/0.01/0.01/0.04, dsn=2.0.0, status=sent (250 2.0.0 <barak@barak-kalai.com> OHCBIQu2l2eyAAAAgPpuPA Saved)
postfix-mailcow-1 | Jan 27 10:36:27 4a70aeedf6c6 postfix/qmgr[347]: 5EE4BDC36F: removed
postfix-mailcow-1 | Jan 27 10:36:27 4a70aeedf6c6 postfix/smtpd[430]: disconnect from unknown[10.7.0.1] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
postfix-mailcow-1 | Jan 27 10:38:25 4a70aeedf6c6 postfix/submission/smtpd[437]: connect from unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:38:26 4a70aeedf6c6 postfix/submission/smtpd[437]: Anonymous TLS connection established from unknown[10.7.0.1]: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits) server-digest SHA256
postfix-mailcow-1 | Jan 27 10:38:26 4a70aeedf6c6 postfix/submission/smtpd[437]: lost connection after STARTTLS from unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:38:26 4a70aeedf6c6 postfix/submission/smtpd[437]: disconnect from unknown[10.7.0.1] ehlo=1 starttls=1 commands=2
postfix-mailcow-1 | Jan 27 10:40:20 4a70aeedf6c6 postfix/postscreen[442]: CONNECT from [10.7.0.1]:36001 to [172.22.1.253]:25
postfix-mailcow-1 | Jan 27 10:40:20 4a70aeedf6c6 whitelist_forwardinghosts: Look up 10.7.0.1 on whitelist, result 200 DUNNO
postfix-mailcow-1 | Jan 27 10:40:20 4a70aeedf6c6 postfix/postscreen[442]: PASS OLD [10.7.0.1]:36001
postfix-mailcow-1 | Jan 27 10:40:20 4a70aeedf6c6 postfix/smtpd[462]: connect from unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:40:21 4a70aeedf6c6 postfix/smtpd[462]: Anonymous TLS connection established from unknown[10.7.0.1]: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits) server-digest SHA256
postfix-mailcow-1 | Jan 27 10:40:22 4a70aeedf6c6 postfix/smtpd[462]: 784BDDC35A: client=unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:44:29 4a70aeedf6c6 postfix/postscreen[472]: CONNECT from [10.7.0.1]:55557 to [172.22.1.253]:25
postfix-mailcow-1 | Jan 27 10:44:29 4a70aeedf6c6 whitelist_forwardinghosts: Look up 10.7.0.1 on whitelist, result 200 DUNNO
postfix-mailcow-1 | Jan 27 10:44:30 4a70aeedf6c6 postfix/postscreen[472]: PASS OLD [10.7.0.1]:55557
postfix-mailcow-1 | Jan 27 10:44:30 4a70aeedf6c6 postfix/smtpd[492]: connect from unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:44:30 4a70aeedf6c6 postfix/smtpd[492]: TLS SNI mail.barak-kalai.com from unknown[10.7.0.1] not matched, using default chain
postfix-mailcow-1 | Jan 27 10:44:30 4a70aeedf6c6 postfix/smtpd[492]: Anonymous TLS connection established from unknown[10.7.0.1]: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits) server-digest SHA256
postfix-mailcow-1 | Jan 27 10:44:33 4a70aeedf6c6 postfix/smtpd[492]: 32289DC36F: client=unknown[10.7.0.1]
postfix-mailcow-1 | Jan 27 10:44:33 4a70aeedf6c6 postfix/cleanup[493]: 32289DC36F: message-id=<0.0.F.C9E.1DB70DA9797AD5A.0@s4.csa1.acemsd5.com>
postfix-mailcow-1 | Jan 27 10:44:35 4a70aeedf6c6 postfix/qmgr[347]: 32289DC36F: from=<barakkalai1+caf_=barak-g=barak-kalai.com@gmail.com>, size=35429, nrcpt=1 (queue active)
rspamd
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <mtbu88>; map; rspamd_re_map_finalize: hyperscan read 45 cached regular expressions from http://fuzzy.mailcow.email/bad-subject-regex.txt
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <mtbu88>; map; rspamd_regexp_list_fin: read regexp list of 45 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <k8f914>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/freemail/disposable.txt.zst from /var/lib/rspamd/ea942f35f2c82e84bdb7b8ceb34537f7dbe986eb.map, 15599 bytes; next check at: 2025-01-27 12:29:27; last modified on: 2024-09-20 12:33:31; etag: (NULL)
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <k8f914>; map; rspamd_kv_list_fin: read hash of 1148 elements from https://maps.rspamd.com/freemail/disposable.txt.zst
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <e99k7g>; map; rspamd_re_map_finalize: regexp map is empty
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <e99k7g>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <c6onet>; map; rspamd_map_read_http_cached_file: read cached data for https://bazaar.abuse.ch/export/txt/md5/recent/ from /var/lib/rspamd/cc4381220e9e543aaba78fb827b20f77c6b96b96.map, 30423 bytes; next check at: 2025-01-27 10:25:55; last modified on: 2025-01-27 10:23:32; etag: "76d7-62cb18a56bf87"
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <c6onet>; map; rspamd_kv_list_fin: read hash of 880 elements from https://bazaar.abuse.ch/export/txt/md5/recent/
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <z7d36p>; map; rspamd_re_map_finalize: regexp map is empty
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <z7d36p>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4ar9sf>; map; rspamd_re_map_finalize: regexp map is empty
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4ar9sf>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <mik73a>; map; rspamd_re_map_finalize: hyperscan read 17 cached regular expressions from /etc/rspamd/custom/bad_words_de.map
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <mik73a>; map; rspamd_regexp_list_fin: read regexp list of 17 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <tk6bew>; map; rspamd_map_helper_insert_re: duplicate re entry found for map /etc/rspamd/custom/bad_words.map: /\slottery\s/i (old value: '1', new: '1')
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <tk6bew>; map; rspamd_re_map_finalize: hyperscan read 28 cached regular expressions from /etc/rspamd/custom/bad_words.map
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <tk6bew>; map; rspamd_regexp_list_fin: read regexp list of 28 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <esqk4o>; map; rspamd_re_map_finalize: regexp map is empty
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <esqk4o>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <b8xy7e>; map; rspamd_re_map_finalize: hyperscan read 65 cached regular expressions from /etc/rspamd/custom/fishy_tlds.map
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <b8xy7e>; map; rspamd_regexp_list_fin: read regexp list of 65 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <uqg9tz>; map; rspamd_radix_fin: read radix trie of 0 elements: ents=0 dup=0 tbm=1 lc=0 mem=1k free=0 waste=0
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <b4if5y>; map; rspamd_kv_list_fin: read hash of 0 elements from /etc/rspamd/custom/bad_asn.map
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <fdp86m>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/freemail/free.txt.zst from /var/lib/rspamd/65b4e39783c10c8ed89dbec4983259f22418f34d.map, 56272 bytes; next check at: 2025-01-27 12:29:27; last modified on: 2023-06-29 11:00:02; etag: (NULL)
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <fdp86m>; map; rspamd_kv_list_fin: read hash of 4007 elements from https://maps.rspamd.com/freemail/free.txt.zst
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <kdbnze>; map; rspamd_re_map_finalize: hyperscan read 19 cached regular expressions from /etc/rspamd/custom/bulk_header.map
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <kdbnze>; map; rspamd_regexp_list_fin: read regexp list of 19 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <eo6s69>; map; read_map_file: /etc/rspamd/custom/chat_versions.map: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <o33omj>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/mime_types.inc.zst from /var/lib/rspamd/2e66b2415ec9b99aaa155761c211e51def12016e.map, 48331 bytes; next check at: 2025-01-27 12:29:27; last modified on: 2024-07-26 04:42:02; etag: (NULL)
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <o33omj>; map; read_map_file: /etc/rspamd/local.d/maps.d/mime_types.inc.local: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <o33omj>; map; read_map_file: /var/lib/rspamd/mime_types.inc.local: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <o33omj>; map; rspamd_kv_list_fin: read hash of 1546 elements from https://maps.rspamd.com/rspamd/mime_types.inc.zst
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <7n3qic>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/mid.inc.zst from /var/lib/rspamd/cb5a8189726ac3a8880e1c44ed6220c6d794521b.map, 997 bytes; next check at: 2025-01-27 12:29:27; last modified on: 2024-01-02 00:42:02; etag: (NULL)
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <7n3qic>; map; read_map_file: /etc/rspamd/local.d/maps.d/mid.inc: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <7n3qic>; map; read_map_file: /etc/rspamd/local.d/mid.inc: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <7n3qic>; map; rspamd_kv_list_fin: read hash of 42 elements from https://maps.rspamd.com/rspamd/mid.inc.zst
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; read_map_static: static: read map data, 182 bytes
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_re_map_finalize: hyperscan read 3 cached regular expressions from static
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_regexp_list_fin: read regexp list of 3 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; read_map_static: static: read map data, 2466 bytes
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_re_map_finalize: hyperscan read 104 cached regular expressions from static
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_regexp_list_fin: read regexp list of 104 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; read_map_static: static: read map data, 589 bytes
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_re_map_finalize: hyperscan read 24 cached regular expressions from static
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_regexp_list_fin: read regexp list of 24 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; read_map_static: static: read map data, 49 bytes
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_re_map_finalize: hyperscan read 2 cached regular expressions from static
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_regexp_list_fin: read regexp list of 2 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <ks7cha>; map; read_map_file: /etc/rspamd/local.d/greylist-whitelist-domains.inc: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <ks7cha>; map; read_map_file: /etc/rspamd/local.d/maps.d/greylist-whitelist-domains.inc: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <rznbhc>; map; rspamd_map_read_http_cached_file: read cached data for http://nginx:8081/forwardinghosts.php from /var/lib/rspamd/e48ac0193da10600fac6a17bb7146ba2421fee67.map, 16 bytes; next check at: 2025-01-27 10:25:55; last modified on: 2025-01-27 10:23:38; etag: (NULL)
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <rznbhc>; map; rspamd_radix_fin: read radix trie of 1 elements: ents=1 dup=0 tbm=0 lc=3 mem=1k free=0 waste=0
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <us4pbz>; map; read_map_file: /etc/rspamd/antivirus.wl: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <ne5d4e>; map; rspamd_radix_fin: read radix trie of 2 elements: ents=2 dup=0 tbm=1 lc=6 mem=1k free=0 waste=0
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; read_map_static: static: read map data, 10 bytes
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <4dego7>; map; rspamd_radix_fin: read radix trie of 1 elements: ents=1 dup=0 tbm=0 lc=3 mem=1k free=0 waste=0
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <xg9x9p>; map; rspamd_re_map_finalize: hyperscan read 6 cached regular expressions from /etc/rspamd/custom/monitoring_nolog.map
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <xg9x9p>; map; rspamd_regexp_list_fin: read regexp list of 6 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <nims7f>; map; read_map_file: /etc/rspamd/local.d/maps.d/exe_clickbait.inc: map file is not found; it will be read automatically if created
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <nims7f>; map; rspamd_re_map_finalize: hyperscan read 15 cached regular expressions from /etc/rspamd/maps.d/exe_clickbait.inc
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <nims7f>; map; rspamd_regexp_list_fin: read regexp list of 15 elements
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; main: rspamd 3.10.2 is starting, build id: release
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; main: cpu features:
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; main: cryptobox configuration: curve25519(libsodium), chacha20(generic), poly1305(libsodium), siphash(libsodium), blake2(libsodium), base64(ref)
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; main: libottery prf: CHACHA20-CRYPTOBOX
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; main: skip writing pid in no-fork mode
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; main: event loop initialised with backend: epoll
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; rspamd_fork_worker: prepare to fork process fuzzy (0); listen on: *
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; rspamd_fork_worker: prepare to fork process rspamd_proxy (0); listen on: rspamd:9900
rspamd-mailcow-1 | 2025-01-27 10:25:55 #36(fuzzy) <00e69b>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #36(fuzzy) <00e69b>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; rspamd_fork_worker: prepare to fork process controller (0); listen on: /var/lib/rspamd/rspamd.sock mode=0666 owner=nobody
rspamd-mailcow-1 | 2025-01-27 10:25:55 #37(rspamd_proxy) <00e69b>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #37(rspamd_proxy) <00e69b>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; rspamd_fork_worker: prepare to fork process normal (0); listen on: *
rspamd-mailcow-1 | 2025-01-27 10:25:55 #38(controller) <00e69b>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #38(controller) <00e69b>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #38(controller) <o3hwd4>; controller; rspamd_controller_password_sane: your normal password is not encrypted, we strongly recommend to replace it with the encrypted one
rspamd-mailcow-1 | 2025-01-27 10:25:55 #38(controller) <o3hwd4>; controller; rspamd_controller_password_sane: enable password is not set, so you should filter controller availability by using of firewall orsecure_ipoption
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; rspamd_fork_worker: prepare to fork process hs_helper (0), no bind socket
rspamd-mailcow-1 | 2025-01-27 10:25:55 #39(normal) <00e69b>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #39(normal) <00e69b>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #1(main) <00e69b>; main; main: listening for control commands on /var/lib/rspamd/rspamd.sock
rspamd-mailcow-1 | 2025-01-27 10:25:55 #40(hs_helper) <00e69b>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
rspamd-mailcow-1 | 2025-01-27 10:25:55 #40(hs_helper) <00e69b>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
rspamd-mailcow-1 | 2025-01-27 10:26:03 #1(main) <00e69b>; main; rspamd_srv_handler: received hyperscan cache loaded from /var/lib/rspamd/
rspamd-mailcow-1 | 2025-01-27 10:26:25 #38(controller) <763f36>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:27:20 #38(controller) <c639fe>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:28:26 #38(controller) <dcde26>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:29:04 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: ASN_CHECK(400): 2027.12 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:05 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: SPF_CHECK(4036): 527.64 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:05 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: MAILSPIKE(543): 571.64 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:05 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: DBL(621): 313.63 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:05 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: DWL_DNSWL(635): 750.63 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:05 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: RBL_INTERSERVER_IP(540): 427.63 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:05 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: SURBL_MULTI(593): 490.07 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:06 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: RBL_SENDERSCORE_REPUT_UNKNOWN(644): 731.07 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:06 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: URIBL_MULTI(602): 745.07 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:06 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: BLOCKLISTDE_CHECK(536): 984.07 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:07 #39(normal) <4E922D>; task; finalize_item: slow asynchronous rule: RBL_VIRUSFREE_UNKNOWN(613): 1998.97 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:29:07 #39(normal) <4E922D>; task; rspamd_task_write_log: id: <CAGHNZE7k5=yt86_HXRMAnbpyanb0v7Kd3aOd2RcYeFCtNRrJYw@mail.gmail.com>, qid: <4E922DA525>, ip: 10.7.0.1, from: <barakkalai1@gmail.com>, (default: F (soft reject): [12.94/15.00] [HFILTER_HOSTNAME_UNKNOWN(8.50){},BAD_REP_POLICIES(2.00){},RDNS_NONE(2.00){},BAYES_SPAM(0.45){75.00%;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},ONCE_RECEIVED(0.10){},MX_GOOD(-0.01){},ARC_NA(0.00){},ARC_SIGNED(0.00){barak-kalai.com:s=dkim:i=1;},DKIM_TRACE(0.00){gmail.com:+;},DMARC_POLICY_ALLOW(0.00){gmail.com;none;},DMARC_POLICY_ALLOW_WITH_FAILURES(0.00){},DWL_DNSWL_NONE(0.00){gmail.com:dkim;},FREEMAIL_ENVFROM(0.00){gmail.com;},FREEMAIL_FROM(0.00){gmail.com;},FROM_EQ_ENVFROM(0.00){},FROM_HAS_DN(0.00){},GREYLIST(0.00){greylisted;Mon, 27 Jan 2025 16:34:07 GMT;new record;},MID_RHS_MATCH_FROMTLD(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},PREVIOUSLY_DELIVERED(0.00){barak@barak-kalai.com;},RCPT_COUNT_ONE(0.00){1;},RCPT_MAILCOW_DOMAIN(0.00){barak-kalai.com;},RCVD_COUNT_ONE(0.00){1;},RCVD_TLS_LAST(0.00){},R_DKIM_ALLOW(0.00){gmail.com:s=20230601;},R_SPF_SOFTFAIL(0.00){~all;},TO_DN_ALL(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 2827, time: 4627.680ms, dns req: 29, digest: <14cb1d69e7f3efa9676ffea094a0ad72>, rcpts: <barak@barak-kalai.com>, mime_rcpts: <barak@barak-kalai.com>, forced: soft reject "Greylisted, please try again later"; score=nan (set by greylist)
rspamd-mailcow-1 | 2025-01-27 10:29:07 #39(normal) <4E922D>; task; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 3 regexps matched, 3543 regexps total, 3270 regexps cached, 0B scanned using pcre, 1.01KiB scanned total
rspamd-mailcow-1 | 2025-01-27 10:29:33 #38(controller) <62b2aa>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:30:02 #38(controller) <37a10e>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:30:16 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: ASN_CHECK(400): 416.99 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: HFILTER_CHECK(425): 313.42 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: MAILSPIKE(543): 384.42 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: RSPAMD_EMAILBL(578): 410.42 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: SPF_CHECK(4036): 471.42 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: DKIM_CHECK(238): 475.42 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: MSBL_EBL(580): 501.42 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: MX_INVALID(513): 548.62 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: RBL_SENDERSCORE_REPUT_UNKNOWN(644): 345.62 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: BLOCKLISTDE_CHECK(536): 403.62 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: RBL_VIRUSFREE_UNKNOWN(613): 428.62 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: SURBL_MULTI(593): 485.62 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:17 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: URIBL_MULTI(602): 606.45 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:18 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: RBL_INTERSERVER_URI(583): 687.45 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:19 #39(normal) <BA0EFD>; task; finalize_item: slow asynchronous rule: RSPAMD_URIBL(611): 1941.43 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:30:19 #39(normal) <BA0EFD>; task; rspamd_task_write_log: id: <0.0.E.DCE.1DB70D6A15B3BB2.0@mta-2d5b2df2.ip4.emsmtp.com>, qid: <BA0EFDA525>, ip: 10.7.0.1, from: <suite57@bounces.mail-ext.movil.com.pa>, (default: F (soft reject): [14.79/15.00] [HFILTER_HOSTNAME_UNKNOWN(8.50){},VIOLATED_DIRECT_SPF(3.50){},RDNS_NONE(2.00){},URI_COUNT_ODD(1.00){19;},DMARC_POLICY_ALLOW_WITH_FAILURES(-0.50){},FORGED_SENDER(0.30){noreply@mail-ext.movil.com.pa;suite57@bounces.mail-ext.movil.com.pa;},R_DKIM_ALLOW(-0.20){mail-ext.movil.com.pa:s=key5;emarsys.net:s=key2;},MANY_INVISIBLE_PARTS(0.10){2;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},ONCE_RECEIVED(0.10){},R_SPF_SOFTFAIL(0.10){~all;},HAS_LIST_UNSUB(-0.01){},MX_GOOD(-0.01){},XM_UA_NO_VERSION(0.01){},ARC_NA(0.00){},ARC_SIGNED(0.00){barak-kalai.com:s=dkim:i=1;},DIRECT_TO_MX(0.00){class SMTPMail;},DKIM_TRACE(0.00){mail-ext.movil.com.pa:+;emarsys.net:+;},DMARC_POLICY_ALLOW(0.00){mail-ext.movil.com.pa;reject;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){noreply@mail-ext.movil.com.pa;suite57@bounces.mail-ext.movil.com.pa;},GREYLIST(0.00){greylisted;Mon, 27 Jan 2025 16:35:19 GMT;new record;},MIME_TRACE(0.00){0:+;1:+;2:~;},RCPT_COUNT_ONE(0.00){1;},RCPT_MAILCOW_DOMAIN(0.00){barak-kalai.com;},RCVD_COUNT_ZERO(0.00){0;},SUBJECT_HAS_EXCLAIM(0.00){},TO_DN_NONE(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 24113, time: 2846.338ms, dns req: 65, digest: <ace6dc56b186d3a5cda30f75f9b8c590>, rcpts: <bkalai@barak-kalai.com>, mime_rcpts: <bkalai@barak-kalai.com>, forced: soft reject "Greylisted, please try again later"; score=nan (set by greylist)
rspamd-mailcow-1 | 2025-01-27 10:30:19 #39(normal) <BA0EFD>; task; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 11 regexps matched, 3543 regexps total, 3286 regexps cached, 0B scanned using pcre, 30.11KiB scanned total
rspamd-mailcow-1 | 2025-01-27 10:30:37 #38(controller) <720534>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:31:55 #38(controller) <9eeafd>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:32:37 #38(controller) <58c6a6>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:33:22 #39(normal) <B4E7AD>; task; rspamd_url_text_extract: got empty text part
rspamd-mailcow-1 | 2025-01-27 10:33:23 #39(normal) <B4E7AD>; task; finalize_item: slow asynchronous rule: SURBL_MULTI(593): 350.99 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:33:23 #39(normal) <B4E7AD>; task; finalize_item: slow asynchronous rule: URIBL_MULTI(602): 442.69 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:33:23 #39(normal) <B4E7AD>; task; rspamd_task_write_log: id: <143-6797b580-3-1ce1eb80@1612712>, qid: <B4E7ADA525>, ip: 172.22.1.248, user: barak@barak-kalai.com, from: <barak@barak-kalai.com>, (default: F (no action): [-17.40/15.00] [MAILCOW_AUTH(-20.00){},FROM_EXCESS_QP(1.20){},FROM_DN_EQ_ADDR(1.00){},MID_RHS_NOT_FQDN(0.50){},MIME_GOOD(-0.10){multipart/alternative;text/plain;},ARC_NA(0.00){},BCC(0.00){},DKIM_SIGNED(0.00){barak-kalai.com:s=dkim;},DYN_RL_CHECK(0.00){},FREEMAIL_ENVRCPT(0.00){gmail.com;},FREEMAIL_TO(0.00){gmail.com;},FROM_EQ_ENVFROM(0.00){},MAILCOW_DOMAIN_HEADER_FROM(0.00){barak-kalai.com;},MIME_TRACE(0.00){0:+;1:+;2:~;},MOO_FOOTER(0.00){},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_ZERO(0.00){0;},TO_DN_NONE(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 700, time: 461.363ms, dns req: 11, digest: <1f5d370937c0717171ea16b8c78c7e66>, rcpts: <barakkalai1@gmail.com>, mime_rcpts: <barakkalai1@gmail.com>
rspamd-mailcow-1 | 2025-01-27 10:33:23 #39(normal) <B4E7AD>; task; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 3 regexps matched, 3543 regexps total, 3240 regexps cached, 0B scanned using pcre, 673B scanned total
rspamd-mailcow-1 | 2025-01-27 10:33:48 #38(controller) <364211>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:34:46 #38(controller) <165cc1>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:35:19 #38(controller) <f702e4>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: ASN_CHECK(400): 405.97 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: MAILSPIKE(543): 387.40 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: SPF_CHECK(4036): 481.40 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: RBL_INTERSERVER_IP(540): 312.40 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: RBL_SENDERSCORE_REPUT_UNKNOWN(644): 309.40 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: URIBL_MULTI(602): 392.39 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: BLOCKLISTDE_CHECK(536): 407.39 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:26 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: RBL_VIRUSFREE_UNKNOWN(613): 437.39 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:27 #38(controller) <e61268>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:36:27 #39(normal) <5EE4BD>; task; finalize_item: slow asynchronous rule: SURBL_MULTI(593): 1027.23 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:36:27 #39(normal) <5EE4BD>; lua; metadata_exporter.lua:317: got unexpected http status: 505
rspamd-mailcow-1 | 2025-01-27 10:36:27 #39(normal) <5EE4BD>; task; rspamd_task_write_log: id: <CAGHNZE7k5=yt86_HXRMAnbpyanb0v7Kd3aOd2RcYeFCtNRrJYw@mail.gmail.com>, qid: <5EE4BDC36F>, ip: 10.7.0.1, from: <barakkalai1@gmail.com>, (default: T (add header): [12.94/15.00] [HFILTER_HOSTNAME_UNKNOWN(8.50){},BAD_REP_POLICIES(2.00){},RDNS_NONE(2.00){},BAYES_SPAM(0.45){75.00%;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},ONCE_RECEIVED(0.10){},MX_GOOD(-0.01){},ARC_NA(0.00){},ARC_SIGNED(0.00){barak-kalai.com:s=dkim:i=1;},BCC(0.00){},DKIM_TRACE(0.00){gmail.com:+;},DMARC_POLICY_ALLOW(0.00){gmail.com;none;},DMARC_POLICY_ALLOW_WITH_FAILURES(0.00){},DWL_DNSWL_NONE(0.00){gmail.com:dkim;},FREEMAIL_ENVFROM(0.00){gmail.com;},FREEMAIL_FROM(0.00){gmail.com;},FROM_EQ_ENVFROM(0.00){},FROM_HAS_DN(0.00){},GREYLIST(0.00){pass;body;},MID_RHS_MATCH_FROMTLD(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},PREVIOUSLY_DELIVERED(0.00){barak@barak-kalai.com;},RCPT_COUNT_ONE(0.00){1;},RCPT_MAILCOW_DOMAIN(0.00){barak-kalai.com;},RCVD_COUNT_ONE(0.00){1;},RCVD_TLS_LAST(0.00){},R_DKIM_ALLOW(0.00){gmail.com:s=20230601;},R_SPF_SOFTFAIL(0.00){~all;},TO_DN_ALL(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 2827, time: 1832.979ms, dns req: 33, digest: <14cb1d69e7f3efa9676ffea094a0ad72>, rcpts: <barak@barak-kalai.com>, mime_rcpts: <barak@barak-kalai.com>
rspamd-mailcow-1 | 2025-01-27 10:36:27 #39(normal) <5EE4BD>; task; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 3 regexps matched, 3543 regexps total, 3270 regexps cached, 0B scanned using pcre, 1.01KiB scanned total
rspamd-mailcow-1 | 2025-01-27 10:36:56 #38(controller) <fe3bd2>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:38:00 #38(controller) <fe5966>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:39:11 #38(controller) <bfbd7d>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:40:07 #38(controller) <b0a555>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:40:55 #38(controller) <29f96f>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:41:56 #38(controller) <a3e8c9>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:42:27 #38(controller) <973f0a>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:43:43 #38(controller) <e25bdf>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:44:32 #38(controller) <005713>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:44:34 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: ASN_CHECK(400): 487.08 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:34 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: MAILSPIKE(543): 386.15 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:34 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: RCVD_IN_DNSWL(553): 479.15 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:34 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: SPF_CHECK(4036): 493.15 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:34 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: DKIM_CHECK(238): 494.15 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: RBL_INTERSERVER_IP(540): 304.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: RSPAMD_EMAILBL(578): 791.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: RBL_INTERSERVER_URI(583): 318.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: SEM_URIBL_FRESH15_UNKNOWN(616): 315.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: RBL_SENDERSCORE_REPUT_UNKNOWN(644): 388.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: RBL_VIRUSFREE_UNKNOWN(613): 420.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: SURBL_MULTI(593): 459.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: URIBL_MULTI(602): 493.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: DWL_DNSWL(635): 496.55 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; finalize_item: slow asynchronous rule: BLOCKLISTDE_CHECK(536): 896.10 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; lua; metadata_exporter.lua:317: got unexpected http status: 505
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; rspamd_task_write_log: id: <0.0.F.C9E.1DB70DA9797AD5A.0@s4.csa1.acemsd5.com>, qid: <32289DC36F>, ip: 10.7.0.1, from: <barakkalai1@gmail.com>, (default: T (add header): [10.69/15.00] [HFILTER_HOSTNAME_UNKNOWN(8.50){},PHISHING(2.00){creativepianoacademy.com->acemlna.com;},RDNS_NONE(2.00){},ARC_ALLOW(-1.00){google.com:s=arc-20240605:i=2;},DMARC_POLICY_ALLOW_WITH_FAILURES(-0.50){},R_DKIM_ALLOW(-0.20){creativepianoacademy.com:s=acdkim1;acems1.com:s=dk;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},HAS_LIST_UNSUB(-0.01){},MX_GOOD(-0.01){},XM_UA_NO_VERSION(0.01){},ARC_SIGNED(0.00){barak-kalai.com:s=dkim:i=3;},ASN(0.00){asn:55720, ipnet:0.0.0.0/0, country:MY;},BCC(0.00){},DKIM_TRACE(0.00){creativepianoacademy.com:+;acems1.com:+;},DMARC_POLICY_ALLOW(0.00){creativepianoacademy.com;none;},FORGED_SENDER(0.00){josef@creativepianoacademy.com;barakkalai1@gmail.com;},FORGED_SENDER_FORWARDING(0.00){},FREEMAIL_ENVFROM(0.00){gmail.com;},FREEMAIL_TO(0.00){gmail.com;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){josef@creativepianoacademy.com;barakkalai1@gmail.com;},FWD_GOOGLE(0.00){barakkalai1@gmail.com;},GREYLIST(0.00){pass;meta;},MIME_TRACE(0.00){0:+;1:+;2:~;},RCPT_COUNT_ONE(0.00){1;},RCPT_MAILCOW_DOMAIN(0.00){barak-kalai.com;},RCVD_COUNT_THREE(0.00){4;},RCVD_TLS_LAST(0.00){},R_SPF_SOFTFAIL(0.00){~all;},SPF_FAIL_FORWARDING(0.00){},TAGGED_FROM(0.00){caf_=barak-g=barak-kalaicom;},TO_DN_NONE(0.00){}]), len: 34920, time: 1881.829ms, dns req: 69, digest: <418a7cfbffeec4bf06ab6948924562f0>, rcpts: <barak-g@barak-kalai.com>, mime_rcpts: <barakkalai1@gmail.com>
rspamd-mailcow-1 | 2025-01-27 10:44:35 #39(normal) <32289D>; task; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 4 regexps matched, 3543 regexps total, 3322 regexps cached, 0B scanned using pcre, 39.32KiB scanned total
rspamd-mailcow-1 | 2025-01-27 10:45:26 #38(controller) <8e2a59>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:45:30 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: MSBL_EBL(580): 329.47 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:30 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: RCVD_IN_DNSWL(553): 348.47 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:30 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: MAILSPIKE(543): 399.47 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:30 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: RBL_VIRUSFREE_UNKNOWN(613): 503.47 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:30 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: RBL_NIXSPAM(642): 503.47 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:30 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: RBL_SENDERSCORE_REPUT_UNKNOWN(644): 503.47 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:30 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: ARC_CHECK(392): 530.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: SEM_URIBL_UNKNOWN(608): 704.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: SEM_URIBL_FRESH15_UNKNOWN(616): 718.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: RSPAMD_URIBL(611): 756.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: DBL(621): 777.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: DWL_DNSWL(635): 789.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: RBL_INTERSERVER_URI(583): 795.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: BLOCKLISTDE_CHECK(536): 411.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: SURBL_MULTI(593): 935.51 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: URIBL_MULTI(602): 1086.69 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: HISTORY_SAVE(450): 1097.69 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; lua; metadata_exporter.lua:317: got unexpected http status: 505
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: EXPORT_METADATA_QUARANTINE(452): 1103.69 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: NEURAL_LEARN(520): 1104.69 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: REPLIES_SET(659): 1104.69 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; finalize_item: slow asynchronous rule: IP_REPUTATION_IDEMPOTENT(665): 1105.69 ms; no idle timer is needed
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; rspamd_task_write_log: id: <00d137f8b256687d5dddef75a.9afd16100a.20250127163025.4d1f143f4d.4c22c42e@mail191.atl21.rsgsv.net>, qid: <4DEE1DC35A>, ip: 10.7.0.1, from: <barakkalai1@gmail.com>, (default: T (reject): [23.19/15.00] [HFILTER_HOSTNAME_UNKNOWN(8.50){},FORGED_W_BAD_POLICY(3.00){},URIBL_GREY(2.50){list-manage.com:url;},BAD_REP_POLICIES(2.00){},HS_BODY_372(2.00){},RDNS_NONE(2.00){},REPLYTO_EXCESS_QP(1.20){},SUSPICIOUS_URL_IN_SUSPICIOUS_MESSAGE(1.00){},URI_COUNT_ODD(1.00){47;},R_DKIM_ALLOW(-0.20){gmail.mcsv.net:s=k2;},MAILLIST(-0.11){generic;},DMARC_POLICY_SOFTFAIL(0.10){giftcardgranny.com : No valid SPF, DKIM not aligned (relaxed);quarantine;sampled_out;},MANY_INVISIBLE_PARTS(0.10){2;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},R_SPF_SOFTFAIL(0.10){~all:c;},ZERO_FONT(0.10){1;},BAYES_SPAM(0.02){53.21%;},HAS_LIST_UNSUB(-0.01){},MX_GOOD(-0.01){},ARC_ALLOW(0.00){google.com:s=arc-20240605:i=2;},ARC_SIGNED(0.00){barak-kalai.com:s=dkim:i=3;},ASN(0.00){asn:55720, ipnet:0.0.0.0/0, country:MY;},BCC(0.00){},DKIM_MIXED(0.00){},DKIM_TRACE(0.00){gmail.mcsv.net:+;send.giftcardgranny.com:~;},DWL_DNSWL_NONE(0.00){mcsv.net:dkim;},FORGED_SENDER(0.00){hello@send.giftcardgranny.com;barakkalai1@gmail.com;},FORGED_SENDER_FORWARDING(0.00){},FORGED_SENDER_MAILLIST(0.00){},FREEMAIL_ENVFROM(0.00){gmail.com;},FREEMAIL_TO(0.00){gmail.com;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){hello@send.giftcardgranny.com;barakkalai1@gmail.com;},FWD_GOOGLE(0.00){barakkalai1@gmail.com;},HAS_REPLYTO(0.00){hello@send.giftcardgranny.com;},MIME_TRACE(0.00){0:+;1:+;2:~;},PRECEDENCE_BULK(0.00){},RCPT_COUNT_ONE(0.00){1;},RCPT_MAILCOW_DOMAIN(0.00){barak-kalai.com;},RCVD_COUNT_THREE(0.00){4;},RCVD_IN_DNSWL_NONE(0.00){205.201.133.191:received;},RCVD_TLS_LAST(0.00){},RECEIVED_HELO_LOCALHOST(0.00){},REDIRECTOR_URL(0.00){list-manage.com;},REPLYTO_ADDR_EQ_FROM(0.00){},REPLYTO_DN_EQ_FROM_DN(0.00){},REPLYTO_DOM_NEQ_TO_DOM(0.00){},R_DKIM_PERMFAIL(0.00){send.giftcardgranny.com:s=k3;},SPF_FAIL_FORWARDING(0.00){},SUBJECT_ENDS_EXCLAIM(0.00){},TAGGED_FROM(0.00){caf_=barak-g=barak-ka
rspamd-mailcow-1 | 2025-01-27 10:45:31 #39(normal) <4DEE1D>; task; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 11 regexps matched, 3543 regexps total, 774 regexps cached, 0B scanned using pcre, 142.83KiB scanned total
rspamd-mailcow-1 | 2025-01-27 10:45:51 #38(controller) <da1ce4>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:46:14 #38(controller) <1462ff>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
rspamd-mailcow-1 | 2025-01-27 10:46:49 #38(controller) <db9d13>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3543 regexps total, 2591 regexps cached, 0B scanned using pcre, 102B scanned total
