• Fflo-m
      Moolevel 0
    Hi all,
    I receive a few spam messages every day which i think should be easily recognized as spam. However, the spam score is quite low.
    May I ask if anybody has an Idea why mailcow / rspamd is behaving this way?
    pflichten-von-unternehmern-zur-datenaktualisierung.eml
    6kB
    pers-reich-durch-bitcoin.eml
    9kB
    info-re-zeptfrei-bestellen.eml
    8kB
    info-wie-geld-verdienen-mit-bitcoin.eml
    9kB
    Thanks a lot guys!
    • DocFraggle
      Moolevel 274
    Funny, I get the same SPAM mails for a few weeks now, but didn’t have the time to get into the details yet…
    EDIT: quick update, I checked the headers of the mails which weren’t flagged. They always have these symbols:
    BAYES_SPAM(4.38)[99.67%];
    BAD_REP_POLICIES(2.00)[];
    IP_REPUTATION_SPAM(1.33)[asn: 53667(0.33), country: US(0.00), ip: 209.141.56.58(0.00)];
    The final score is <8 which is my current limit to flag mails. So I went ahead and adjusted these sysmbols via the Rspamd UI. I set the following values:
    BAYES_SPAM = 6 (default 4.5)
    IP_REPUTATION_SPAM = 6 (default 4.5)
    BAD_REP_POLICIES = 3 (default 2)
    Let’s see if this changes things
    • Fflo-m
        Moolevel 0
      Thanks for your reply. I will try to adapt the settings.
      Also i’ve seen that those mails get the symbol BAD_WORDS and/or BAD_WORDS_DE, but with a funny low value of 0.1, resulting in e.g.
      BAD_WORDS_DE(0.20)[];
      Do you think it’s safe to increse this to, lets say, 5-8 ? (with default header + reject settings)
        • DocFraggle
          Moolevel 274
        flo-m Do you think it’s safe to increse this to, lets say, 5-8
        Hmm… I would be careful with that…
        BTW, I checked two of your attached mails, they don’t have the BAYES symbol… do you regularly move those mails into the SPAM folder in order for Rspamd to learn them as SPAM?
          • Fflo-m
              Moolevel 0
            DocFraggle
            yes, i regulary move those to the spam folder for my accounts. Maybe it needs more training, as my spam/ham db is only +/- 250 learns…
            2 months later
            • Felix
                Moolevel 0
              I use this custom Lua snippet in my data/conf/rspamd/lua/rspamd.local.lua for exactly this type of spam:
              rspamd_config:register_symbol({
                name = "SUBJECT_STARTS_WITH_LOCAL",
                type = "normal",
                callback = function(task)
                  local util = require("rspamd_util")
                  local lua_util = require("lua_util")
                  local to = task:get_header("To")
                  local subject = task:get_header("Subject")
                  if to == nil or subject == nil then
                    return false
                  end
                  local lp = util.parse_mail_address(to, task:get_mempool())
                  return lp ~= nil and #lp == 1 and lp[1]["user"] ~= nil and lua_util.str_startswith(subject, lp[1]["user"])
                end,
                score = 4.0,
                description = "Subject starts with local part of To",
              It checks if the subject begins with the local part of the email address (e.g. info for info@example.com).
