I am trying to get all my emails into my other app using the API, but I can’t find a way.
English
How i get all mails from my mailbox?
- Edited
The API is not capable oft his and also has no need to. Use IMAP as the protocol of choice which has been designed for such things. There is no need to re-invent the wheel.
pkernstock, can you guide me regarding IMAP? Is there any call through which I can get my mailbox emails?
This would be a great help.
IMAP is the most well-known de-facto standard for retrieving emails - beyond ActiveSync. There are hundreds of different libraries you can use if you don’t want to write your own IMAP implementation.
Thanks, a lot. i will try
