DocFraggle
I don’t remember. It was a while ago I installed this. If I did it manually I did it from some instructions I was following . I will correct it. Thanks
So what is this actually doing because my mailcow seems to be working fine even tho this is wrong.
Now I see this. It could have been there before and I didn’t notice it.
postfix-mailcow-1 | chown: cannot access '/usr/share/man/man1/mailq.1.gz': No such file or directory
postfix-mailcow-1 | /usr/sbin/postconf: warning: /opt/postfix/conf/main.cf, line 211: overriding earlier entry: smtpd_recipient_restrictions=check_recipient_mx_access proxy:mysql:/opt/postfix/conf/sql/mysql_mbr_access_maps.cf, permit_sasl_authenticated, permit_mynetworks, check_recipient_access proxy:mysql:/opt/postfix/conf/sql/mysql_tls_enforce_in_policy.cf, reject_invalid_helo_hostname, reject_unauth_destination
postfix-mailcow-1 | /usr/sbin/postconf: warning: /opt/postfix/conf/main.cf, line 92: overriding earlier entry: smtpd_recipient_restrictions=check_recipient_mx_access proxy:mysql:/opt/postfix/conf/sql/mysql_mbr_access_maps.cf,?reject_rbl_client zen.spamhaus.org=127.0.0.[2..11]
postfix-mailcow-1 | postsuper: warning: /opt/postfix/conf/main.cf, line 211: overriding earlier entry: smtpd_recipient_restrictions=check_recipient_mx_access proxy:mysql:/opt/postfix/conf/sql/mysql_mbr_access_maps.cf, permit_sasl_authenticated, permit_mynetworks, check_recipient_access proxy:mysql:/opt/postfix/conf/sql/mysql_tls_enforce_in_policy.cf, reject_invalid_helo_hostname, reject_unauth_destination
