esackbauer In my case, I’ve tested it with external email domain and the result is the same. If you add a meeting by dragging the right interval and without invites, it shows up correctly. Then you double click to edit it and add the invite… then when you save it, it will set the start time to 00:00 (even if on the page before it showed and afternoon hour, for example)
It would be nice to know if others have the same issue with SOGo or it is something with my mailcow-dockerized installation.
esackbauer It would be nice to know if others have the same issue with SOGo or it is something with my mailcow-dockerized installation.
