Is there anyone who has faced the following error when I try to migrate an Exchange user’s mailbox using sync jobs
Host2 banner: * OK [CAPABILITY IMAP4rev1 SASL-IR LOGIN-REFERRALS ID ENABLE IDLE LITERAL+ AUTH=PLAIN AUTH=LOGIN] Dovecot ready.
Host2 capability before authentication: IMAP4rev1 SASL-IR LOGIN-REFERRALS ID ENABLE IDLE LITERAL+ AUTH=PLAIN AUTH=LOGIN AUTH
Host2: localhost says it has CAPABILITY for AUTHENTICATE LOGIN
Host2: success login on [localhost] with user [abc@example.comfcjq514l2kzi0h2g@mailcow.local] auth [LOGIN] or [LOGIN]
++++ Listing 1 errors encountered during the sync ( avoid this listing with –noerrorsdump ).
Err 1/1: Host1 failure: can not open imap connection on host1 [mail.example.com] with user [abc@example.com]: socket closed while reading data from server
The most frequent error is ERR_CONNECTION_FAILURE_HOST1. Check that host1 mail.example.com on port 143 is the right IMAP server to be contacted for your mailbox.
Exiting with return value 101 (EXIT_CONNECTION_FAILURE_HOST1) 1/50 nb_errors/max_errors PID 1338
Disconnecting from host2 localhost user2 abc@example.comfcjq514l2kzi0h2g@mailcow.local
No log file because of option –nolog
