nnoblast I have information but this is my first time using docker Edit or create data/conf/dovecot/extra.conf how to create or edit a file?
DocFraggle https://ubuntu.com/tutorials/command-line-for-beginners#1-overview Please learn the basics!!!
DocFraggle Are you sure you want to run a complex groupware solution without even knowing how to create/edit a file on a Linux system?
nnoblast DocFraggle nano editor can edit and create a file. If you don’t know this, then why are you writing an answer? I start public folder in system Postfix+Dovecot+Sogo but i dont work Dockker and Mailcow.
